speed shifting
ORIGINAL: so1o2k3
So the rumor that there is a "perfect" rpm when you can shift without using the clutch is a myth? I've heard this from a couple of people.
Edit: i must add tho, it is harder to do in a "sports car", such as a 'Stang, at least the V8's due to most of them having a close-ratio tranny. i can mine to do it sometimes, but, if i dont, it just doesnt go in...no grinding. just, doesnt go. lol
Hey bro, there are going to be MANY, MANY different opinions on the best way to shift. I grew up drag racing and everyone does it there own way.
If you don't have a short throw shifter, GET ONE. I recomend MGW. I have it and I love it. It is the shortest throw of any I have dealt with, and It works slick too.
When you shift try to find out the point on your clutch peddle where it actually engages and then just push it in to that point instead of on the floor. And when you take your foot off the gas just quickly back it off to about half throttle then slam it back down again after you shift. You should have changed gears before the RPM's reach half throttle so there is no point in taking your foot completely off the gas. IF NOT practice on your shifts. I hope something in here helps you man. Cause there is no better feeling than running through gears.
"Some have it naturally, God given. Others have to work at it all their lives and still be disappointed when they die." SGT D.
the only way you can shift without the clutch is if you have a trans that they call a crash box. there are no syncros in it. u pull and push hard. No one runs them anymore it was a 60's and 70's thing.
ORIGINAL: Tims 88GT
ORIGINAL: Tims 88GT
ORIGINAL: 91hatchgt
Not true... You can shift without the clutch with our T-5's.. In fact, when I blew my clutch into a million pieces the other night at the track, I drove it home. Not fun, but It shifted fine.
ORIGINAL: Tims 88GT
ORIGINAL: JD1969
Yes you can, but not at wide open throttle. Even with a Pro-Shifted trans (the red car in mysig has one) which has not syncos and stright cut gears, you still use the clutch.
ORIGINAL: lxragtop50
i never understood wat double clutchin was. explain?
