Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
drag radial problem
Old Aug 26, 2007 | 09:02 PM
moparrr07's Avatar
moparrr07
Default RE: drag radial problem
the only way to build heat in the tire is to get the wheel speed up, so dont even bother with a 1st gear burnout, do a second to third, in any car
you should never have to do long burnouts, the more tire speed the faster it heats up
Old Aug 27, 2007 | 12:39 AM
Sleeper05's Avatar
Sleeper05
ORIGINAL: moparrr07
I wholly agree, if by "long" you mean more than 5-6 seconds. It is simple physics that the tire speed will glaze over and the extra friction will raise the temp of the glazed over surface rather than chunk it off with lower speed spin.
ORIGINAL: moparrr07
In an automatic that might be slightly possible. In a manual, why the fock would you ever risk clutch and tranny to try a THIRD GEAR BURNOUT?????? Have you even ever drag raced?
Old Aug 27, 2007 | 01:42 AM
fazm's Avatar
fazm
ORIGINAL: Sleeper05
sure dont sound like he has....
3rd gear LOL. thatd be between 70-100mph in the burnout box for my car hahah
1st gear at 35mph works just fine.
Old Aug 27, 2007 | 02:36 AM
01snake's Avatar
01snake
WOAH
we are all forgeting that tires will not give you better traction alone
you need to look at your suspension also: strut bars, subframe connectors, sturt stiffners, control arms. etc.....
my best 1/8th was a 8.673
on street tires (nitto555's)
60' was 2.097
getting nasty irs hop and wheel spin thru 1st and 2nd
also maby try launching a little lower in the rpms
Tivo304
Aug 28, 2023 12:19 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Sep 15, 2015 07:34 PM
vintageaion
Sep 8, 2015 10:45 AM
