Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Talon!?
Old Aug 31, 2007 | 06:31 PM
  #21
joshafmil's Avatar
joshafmil
Default RE: Talon!?
ORIGINAL: socmmedic
embarrass him? you have a V6, and he has a turbo talon. you are not going to embarrass him...
ditto
the best part is, it already has a turbo, so you dont know what the hell hes running. sell your v6 and get a foxy and work on it, or get a used mach 1 or something. [8D]
Old Sep 1, 2007 | 12:05 AM
  #22
fazm's Avatar
fazm
Default RE: Talon!?
or just put a turbo on your car
Old Sep 1, 2007 | 10:37 AM
  #23
TRBOPWR's Avatar
TRBOPWR
Default RE: Talon!?
ORIGINAL: Morbid
also.. if you look at the first run closely he was absolutely covering me in smoke out of his exhaustbetween his shifts, def not a nicely setup car
Wow, that was a lot of smoke! It has been my experience that turbo cars tend to smoke a bit under full throttle, but that is way excessive.
Old Sep 1, 2007 | 11:04 AM
  #24
Demon 340's Avatar
Demon 340
Administrator
Default RE: Talon!?
my car right now runs very rich due to a boost leak, so if im sitting in traffic, or idling a ton, when i do get on it, it spits out a ton of carbon...
Old Sep 1, 2007 | 12:42 PM
  #25
sw07gt's Avatar
sw07gt
Default RE: Talon!?
Theres 3 talons in my town that are heavily modded and run low 6's in the 1/8. They can be modded pretty cheaply so watch out.
Old Sep 1, 2007 | 02:18 PM
  #26
buster's Avatar
buster
Default RE: Talon!?
Eagle Talons are the Forest Gumps of the auto world. They are like a box of choclates, you just never know what you are going to get. I saw one last night at Milan in Detroit run 9.08. I've also seen them run high 15s.
Old Sep 2, 2007 | 09:51 AM
  #27
BoOsTeDeAgLe's Avatar
BoOsTeDeAgLe
Default RE: Talon!?
ORIGINAL: buster
Lol, never heard that one, but I'll agree, it could be fast or a flat-out dog. Seeing that he revs at everything, I bet he's not out of the 14's yet.
Old Sep 4, 2007 | 11:17 AM
  #28
buster's Avatar
buster
Default RE: Talon!?
ORIGINAL: BoOsTeDeAgLe
ORIGINAL: buster
The only problem with them is that its not a question of IF they are going to grenade the clutch, but WHEN
Old Sep 6, 2007 | 11:10 AM
  #29
BoOsTeDeAgLe
Default RE: Talon!?
ORIGINAL: buster
ORIGINAL: buster
Yup, their clutches aren't made for anything more than normal driving or stock boost. Heh, when I pulled the original out to replace it, it fell off in about 4 pieces with springs flying all over, guess I was a little rough on it[&o]
Old Sep 6, 2007 | 11:37 AM
  #30
OneFastEclipse's Avatar
OneFastEclipse
Default RE: Talon!?
ORIGINAL: Ride Of The Month
shep ran high7s with street tires...and im pretty sure that last year he got into the deep 7s with slicks. its sick.
im only running stock boost, with the stock boost restrictor...so around 10psi with the full exhaust, but ive been told that removing the restrictor will give me another pound or so...and the 1g will handle 14psi at the manifold with no other upgrades, and 14-15 is around the max for the stock turbo..some guys are running it higher, but it will only spike higher, and flatten out to around 15psi.
Shepard ran his best time of 7.7 at 191 mph using Mickey Thompson slicks on all four tires. Regardless, yes his car is nasty.
The 1g turbo is the 14b and it is capable of pushing around 20lbs of usable boost. If you upgrade the stock fuel pump on the 1g, you can easily run 17-18psi with no problems. A 1g with downpipe, full exhaust, intake, fuel pump, and boost controller can easily see mid to low 13's with a good aggressive driver. 2g's on the other hand used the T25 turbo which is much smaller then the 14b. 14b is actually a common cheap upgrade for the 2g's. A 2g with the same bolt ons as the 1g using the stock turbo usually sees low 14's, high 13's.
To the original poster, if you can hear his turbo, he's not stock. Completely stock DSM's were relatively quiet. Once you get a intake on them, they speak up more. If he is AWD and very mildly modded, your only chance is to race from a roll. The AWD's will destroy lots of things out of the hole, but they loose quite a bit of their power through the drivetrain. If he is FWD, I'd try and do the exact opposite and go from a dig and try to edge him out with a good launch from the RWD. These cars are light and stock have comparable HP to your own.
