Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
lt1
Old Dec 4, 2007 | 04:58 PM
  #21
The Stig's Avatar
The Stig
Default RE: lt1
ORIGINAL: tspence45
What's speed density?
I cant garentee the reliability of this source, but:
http://www.carcraft.com/techarticles...ion/index.html
Old Dec 4, 2007 | 05:00 PM
  #22
98LS1's Avatar
98LS1
Default RE: lt1
ORIGINAL: tspence45
Saves me from typing it out...
Speed Density systems accept input from sensors that measure engine speed (in rpm) and load (manifold vacuum in kPa), then the computer calculates airflow requirements by referring to a much larger (in comparison to an N Alpha system) preprogrammed lookup table, a map of thousands of values that equates to the engine’s volumetric efficiency (VE) under varying conditions of throttle position and engine speed. Engine rpm is provided via a tach signal, while vacuum is transmitted via an intake manifold-mounted Manifold Air Pressure (MAP) sensor. Since air density changes with air temperature, an intake manifold-mounted sensor is also used.
Production-based Speed Density computers also utilize an oxygen (O2) sensor mounted in the exhaust tract. The computer looks at the air/fuel ratio from the O2 sensor and corrects the fuel delivery for any errors. This helps compensate for wear and tear and production variables. Other sensors on a typical Speed Density system usually include an idle-air control motor to help regulate idle speed, a throttle-position sensor that transmits the percentage of throttle opening, a coolant-temperature sensor, and a knock sensor as a final fail-safe that hears detonation so the computer can retard timing as needed.
GM’s Tuned Port Injection (TPI) set-ups used Speed Density metering from ’90-’92, as did ’91-’93 LT1 engines. All ’86-’87 and ’88 non-California Ford 5.0L-HO engines used Speed Density metering. Most Mopar fuel- injection systems have used Speed Density too.
Because a Speed Density system still has no sensors that directly measure engine airflow, all the fuel mapping points must be preprogrammed, so any significant change to the engine that alters its VE requires reprogramming the computer.
Old Dec 5, 2007 | 11:41 AM
  #23
dferkler's Avatar
dferkler
Default RE: lt1
my imaginary car rocks!!
I am saving up for a Neon.
Old Dec 5, 2007 | 12:11 PM
  #24
EaZy DuZ iT's Avatar
EaZy DuZ iT
Default RE: lt1
late
Old Dec 5, 2007 | 04:01 PM
  #25
LT1RUNNER's Avatar
LT1RUNNER
Default RE: lt1
The LT1 is a good stout motor and like the Fox-body it is now better than ever to add performance parts. The after market has stepped up and the parts are not expensive. Something to look into.
w8less
Feb 5, 2006 04:14 AM
1990foxconvert
Jan 18, 2006 08:00 PM
00MustangGT
Aug 15, 2004 05:22 PM
Dan04COBRA
Jul 30, 2004 12:08 AM
00MustangGT
May 16, 2004 09:28 PM
