Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Audi S4
Old Mar 26, 2005 | 08:05 PM
JonBeast's Avatar
JonBeast
Moderator
Default RE: Audi S4
ORIGINAL: David_K
S4's are sick. There whole motor is forged and can take 22psi of boost. the stock s4 runs 9psi of boost and puts about 300 to all four wheels. but with $500 for a chip the boost is increased to 14 psi and itll put like 350-360 to the ground which is about 400 to the fly.
The RS6 has a biturbo 4.2L V8 that puts 450 to all four wheels.
Yea, I had a feeling Derf00's sources were wack. There was no way the guy I raced ran 15.1's. He smoked me. It was a sweet car, thanks for the imput David, i figured you knew quite a bit about S4's, considering you had, or still have, a mad fast audi.
Old Mar 26, 2005 | 08:40 PM
David_K's Avatar
David_K
Default RE: Audi S4
the 99 S4 was a 2.2L inline 5 cylinder turbo the 2000 - 2002 were 2.7L v6 BiTurbo ans 2003 - 2005 are 4.2L V8
Old Mar 26, 2005 | 08:44 PM
JonBeast's Avatar
JonBeast
Moderator
Default RE: Audi S4
ORIGINAL: David_K
The guy said it was a 2.7L v6 twin turbo, but we knows its a bi-turbo. His must have been a 02 then, it looked new and very clean. They are sweet cars. There was an S8 in the lot when we pulled in, what kind of numbers do they put out?
Old Mar 26, 2005 | 10:38 PM
Mach1's Avatar
Mach1
Default RE: Audi S4
Ya i got to test drive an s4 once, hell of a nice car. They got 2 turbos so im sure they take very well to mods.
Old Mar 22, 2008 | 01:11 PM
audiguy's Avatar
audiguy
Default RE: Audi S4
Hi guys,
There's a bit of misinformation here. The 2.2 turbo S4 is from 1992-1994, followed by the 1995 S6. They are the same car, and are the midsize chassis. The 1999-2001 S4 is a small chassis car based on the A4. The 1999-2001 use the Bi-turbo 2.7 (twin turbo is just different semantics). This car does 250 hp stock, but are relatively easy to get into the 550ish range. The 2002+ uses a 4.2 v8 at 340 hp, but unfortunately there'sno boost.
If you wanna know more about fast Audi's, there's a guy @ 034motorsport who recently put down 720 hp at the wheels with a 2.3 motor based off the one in my car. The last time the car ran in the 1320, I think it ran somewhere in the 11's @ 130+...and the only thing keeeping him from being in the 10's is the axle strength (he breaks them often).
*edit* Got a link from elsewhere, and didn't see how old this was till it was too late. Delete if necessary.
Old Mar 22, 2008 | 01:52 PM
BicketyBam's Avatar
BicketyBam
Default RE: Audi S4
No prob - **** happens. I raced a V8 S4 in my old blown 2000 Mustang. Two kids were in it. We went from a stop light and I started behind them. I tore them a new a$$hole. Good times.
Old Mar 22, 2008 | 02:05 PM
Subotai_95's Avatar
Subotai_95
Default RE: Audi S4
I've seen some fast Audi's, but I would still have to say this is my favorite...
[IMG]local://upfiles/90875/D5CB4AA2FAE64D629D6A371DED0D198E.jpg[/IMG]
[IMG]local://upfiles/90875/D5AD1C2B6A1342579820B1FB8CEDE87C.jpg[/IMG]
Old Mar 22, 2008 | 02:16 PM
scg87's Avatar
scg87
Default RE: Audi S4
ORIGINAL: audiguy
Hi guys,
Still incorrect on some points. The 2.7T powered B5 S4 extended all the way to the 2002 model year. There was no 2003. The 2004 S4 of the B6 gen debuted in mid 2003 and yes, used the 340hp 4.2 V8.
There was a lot of other misinfo in the old posts, but I won't touch it.
And the upcoming B8 S4 is going back to a forced-induction 6, so watch out for it.....
Old Mar 22, 2008 | 03:09 PM
Projectquick's Avatar
Projectquick
Default RE: Audi S4
Who ever said that they get 300 to the wheels needs to put down the crack pipe. Those cars are good for 250 at the crank, and yes with a few mods and not a lot of $$$ they can be killers. A local kid who is into v-dubs and audi has an 02 S4 running like 20 lbs. of boost and runs DRs. He pulls mid 12s all day, but only because he can't get all four tires to stop spinning long enough to get decent 60' times. For the OP its nothing to be ashamed of losing to a FI car especially one with so much potential. The ones with the V8s though are suprisingly not fast. I came across one on the highway when I had the new edge and even with an exhaust he could not pull in front of me at about 120 ish.
Old Mar 22, 2008 | 04:17 PM
Trmachuno's Avatar
Trmachuno
Default RE: Audi S4
What car, engine, and mods does the op have? And I am clueless when it comes to audis, so whatis the S4 MSRP/invoice price? Thanks to whoever can tell me that b/c I have no idea what the op's car is or how fast a stock S4 is and how much they run.
