Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
popped my cherry
Old Jul 3, 2008 | 12:10 AM
GOTTORQ's Avatar
GOTTORQ
Default popped my cherry
i went to the track tonight for the first time in my mustang, ive been previously in my car before the mustang a lancer..anyways, i did pretty well, i have an JLT intake, xcal3, and pypes mid muffs, my first run of the night was:
R/T- .143
60 ft- 2.3
330- 6.523
1/8- 9.32
MPH-79.228
1/4- 14.202
mph- 100.2
my second run was
R/T-.137
60 ft- 2.269
330- 6.220
1/8- 9.3
MPH- 80.98
1/4- 14.020
MPH- 101.52
my last run was my best run of 13.8...i dropped the tire pressue from 35 to 25 psi
R/T-.201
60 ft- 1.897
330- 5.893
1/8-8.896
MPH-79.85
1/4-13.826
MPH-102.66
dont think i did too bad, for just and CAI/ Tune and exhaust
Old Jul 3, 2008 | 12:21 AM
Blue Meanie's Avatar
Blue Meanie
Default RE: popped my cherry
You cut a nice 60' on the last run. Looks like you need to brush up on your powershifting. There's more in there.
Old Jul 3, 2008 | 01:15 AM
Mishri's Avatar
Mishri
Mish-ogynist
+1 I believe you are right.. however.. do you know what the DA was there? I'm guessing there in CT you aren't at a high elevation so Blue Meanie is probably right.. if you are anywhere under 1500 DA i'd guess people would say you should be capable of a 13.1-13.4 w/o any problem (a couple of people have hit sub 13's with intake/tune alone).. Good luck! not bad for your first time!
edit: im planning on going tommorow for my first time.. with a typical DA of around 6600 im hoping for low 14s
Old Jul 3, 2008 | 08:52 AM
GOTTORQ's Avatar
GOTTORQ
the DA i think is around 360 feet, i got 3 runs in my last run being the best, my fourth run i went lower my time and i screwed up bad, i dropped my tires psi 2 more lbs and brought my launch up to 4K, took off great off the line, but missed 2nd, so i was like f*******k, and it was everyones last run, cuz the track stops racing at 10
Old Jul 3, 2008 | 11:05 AM
SINISTER's Avatar
SINISTER
Not bad for the first time out. You'll get better as you practice.
Old Jul 3, 2008 | 12:30 PM
bluebeastsrt's Avatar
bluebeastsrt
Looks like a steady improvement from your first to lst run. keep at it, you still have alot left in your car amd you'll get better with more practice. I pretty much say this to everyone. If you plan on going to the drag strip alot get a set of slicks or drag radials. You'll probably be better off at your power level with the DRs.
Old Jul 3, 2008 | 01:10 PM
GOTTORQ's Avatar
GOTTORQ
ORIGINAL: bluebeastsrt
thanks for the tips, i plan on getting some new rims, possibly 18 inch black bullets, i think my dad is going to take my rims and im going to grab two of his rims and put some drag radials on them, he has the stock 17 inch ones, deff alot better for racing..i plan to add alot more mods, i think my stock 3.31s are killing me too..ur from jersey? u head to e-town and atco alot?
Old Jul 3, 2008 | 01:17 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
U topping out the 1/4 in 3rd gear? You have great '60 time with stock rubber at x1.8 my changing your gearing will not yield you better time with stock tires as you will spin more. With stickies taller gearing will help.
I went last night also my best '60 was 2.2 no traction.
Old Jul 3, 2008 | 10:41 PM
GOTTORQ's Avatar
GOTTORQ
lol i honestly dont remember what gear i was in, i think i shifted into 4th..i didnt cut a 1.8 until i dropped some psi
cr620
Oct 3, 2022 10:18 PM
MacSerio
Sep 27, 2015 01:05 PM
humpbackshooter
Sep 24, 2015 10:07 AM
gagemcc
Sep 22, 2015 09:43 AM
Sminemann
Sep 17, 2015 09:24 AM
