Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
How much does 60' effect ET??
Old Sep 10, 2013 | 06:42 AM
S8ER01Z's Avatar
S8ER01Z
Last weeks example.... as stated above...varies to a degree but you can ballpark it.
2.020 60ft - 12.421
1.955 60ft - 12.271
0.65 diff = .15 ET
In this case every tenth would be worth .24
Old Sep 14, 2013 | 11:02 AM
TommyV8's Avatar
TommyV8
My experience has been the same as Mishri's, .1 60 ft reduction = .1 ET reduction. A car that has traction problems even beyond the 60 ft mark may see different results after correcting the problem. Also, a good torque converter will help your ET down the whole track, not just on the launch. I think that may be where the idea came from that somehow cutting time rarly in the run is more important. On all of my timeslips from any given track outing, the variance in the 60 ft times matches the variance in the overall ET.
Old Sep 14, 2013 | 10:31 PM
88 orangepeel notch's Avatar
88 orangepeel notch
Here's what I've done. Bought the car with an AOD with 3000 stall and shift kit. Street tires, no spin.
Best time ……13.5 @ 108, 2.20 60ft.
Swapped to T5, and big and littles with 26x8 ETDrags
Best time…… 12.4 @ 108, 1.66 60ft.
Your 60ft is everything, well at my power level at least.
Old Sep 30, 2013 | 08:46 AM
95 BLOWN GT's Avatar
95 BLOWN GT
60 foot very important...just ran saturday spun and got out of it 3 times...no trac prep and me no slicks.....mph was great... 60 foot no traction bad
60 foot 2.141
1/8th 8.304 et
1/8th mph 91.59
1/4 et 12.466
1/4 mph 116.64
Old Sep 30, 2013 | 11:57 AM
Mishri's Avatar
Mishri
Mish-ogynist
That is an interesting point, are most of you letting off when you start spinning on launch? that would explain bad 60' = more than 1:1 difference. With me I just stayed on it because I never spun bad enough to worry about it... and with the auto it's just floor it the whole time...
I think 88orangepeel notchs results aren't really comparing just 60' difference, you have more power at the tires with the manual and the big&lils and can launch higher.
I think the OP's times could be better with tires, and possibly better driving.. but likely tires.
Old Sep 30, 2013 | 01:49 PM
95 BLOWN GT
I was getting out to straighten the car...then it spun again till i hit second.....in hindsight i should have tried starting out in second to see what would happen.
Old Oct 1, 2013 | 09:07 PM
Stone629's Avatar
Stone629
I NEVER stay in it once I start spinning. It'll never stop spinning if I don't, and if I try to get back into it she'll kick down a gear and just break loose again.
Old Oct 2, 2013 | 06:28 AM
S8ER01Z's Avatar
S8ER01Z
I've rarely spun... I seem to bog on almost every launch, the runs where I get any amount of spin I let out/feather and they are usually really bad compared to a clean run.
Drastang
Sep 30, 2015 03:48 AM
Sep 8, 2015 11:50 AM
90Mustangfan
Mar 3, 2004 10:14 PM
cobra69
Jul 27, 2003 02:56 PM
Stang Chick
Jun 22, 2003 08:53 PM
