SVT Forums
Upper pulley change questions.
Old Jul 10, 2006 | 01:01 PM
brwafl's Avatar
brwafl
Default Upper pulley change questions.
How small of an upper pulley can I put on without out having to worry about over heating? I do autocross and road course events so the supercharger runs for extended periods of time. Also will I need a tensioner and a new belt?
Old Jul 11, 2006 | 01:54 AM
mg01svt's Avatar
mg01svt
Default RE: Upper pulley change questions.
Kinda of a tough question to answer. Personally, I would not open track my car without the evans cooling mods or a heat exchanger with anythiing smaller than a 2.93. To get the most contact between pulley and belt you will need an auxilary idler and a new belt.
A
Old Jul 13, 2006 | 05:24 PM
Dan04COBRA's Avatar
Dan04COBRA
Even with a stock pulley Cobra, it's smart to have some cooling mods done. Those Eaton's produce more heat than you care to know about.
Old Jul 16, 2006 | 01:53 PM
RR03Cobra's Avatar
RR03Cobra
I also recommend a heat exchanger with a pulley change! Your IAT temps will increase with ANY pulley change, which in some cases can cause your computer to pull timing during WOT!! As far as belts go, if you get an aux. snub idler (which will help for belt slip) you can use your stock belt, down to a 3.0 diameter. Make sure you get a Custom tune for your car with a pulley change!! This is vital to the life of your engine. Many of the internal parameters need to be changed to compensate for the added boost!
Old Jul 18, 2006 | 02:32 PM
freewilly's Avatar
freewilly
I ♥ Acer
i got an 03 with 2.76 pulley ,and im going with a 4 lb lower. get a bigger heat exchaner with the fans on it .my stock pulley the temp at the H/E was 105, with 2.76 pulley it gets to 134. so yes a cool one iam getting ill post a link hang one if i can find it .
Old Jul 20, 2006 | 12:27 PM
freewilly's Avatar
freewilly
I ♥ Acer
i forgot the link, do i google on the gords heat exchanger.
spdeplayer2
Oct 24, 2015 09:45 AM
ctgreddy
Sep 20, 2015 08:35 PM
MusicCity615
Sep 12, 2015 07:05 AM
Gabe_mlcc
Sep 7, 2015 11:56 PM
cbird1177711
Sep 2, 2015 08:51 PM
