97 Mustang Cobra Vortech Supercharger Smokin...Whats wrong
RE: 97 Mustang Cobra Vortech Supercharger Smokin...Whats wrong
ok so u made me start thinkin and i went to the shop tonight around 11:30 and checked the pcv line...not a drop of oil anywhere...but the power pipe comin out of the supercharger into the filter had oilresidue all over it...
ORIGINAL: du5ty
im sorry if i misled u or anything, but i was just talkin from experience. i have gone through 3 cobra motors and im on my 4th. on my second motor, my car had similar symptoms like ur car. Burnin oil through the exhaust. it started off mildly but eventually got worse. It was a stock 2001 cobra motor with a procharger p1sc at 7 lbs of boost. I found oil leaking out of the airfilter on the inlet pipe, so i just assumed it was my procharger. i removed the supercharger to get the seals replaced by procharger. cost me about $450.well after i got it back and installed, same problem. Burning oil, and oil dripping from the air filter out of the inlet pipe. needless to say, it made a real mess, because that oil went thru the supercharger into the intercooler over the spark plugsand eventualy thru the motor and out the exhaust. Well then i checked again and found out what it really was. i disconnected my fresh air return line of the pcv system that connects to the intake. i started the car, and low and behold, oil was gettin sprayed out of the crank case!! in like a mist form, and when i really got on it, it was loosin a lot of oil. Well turned out my bottom end was expiriing, and my pistons had seen some detonation and was not holdin compression. That was my last stock motor.
unhealthy tune+ stock motor on boost = boom!
i have a 97 cobra with 39000 miles on a stock motor...vortech supercharger making 8 lbs. of boost and a few other goodies...its makin 449 rwhp...when i bought the car i was told it runs rich...but now im worried its runnin to rich...or is something else goin on...the problem is i got in it today to go for a ride and there was a lot of smoke comin out the exhaust...its always had a little but today was a big difference...anyone know what could be goin on????
Diode Dynamics
28
05-26-2022 12:02 PM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
Soldier GT
08-12-2015 03:46 PM
1997, 97, bad, cobra, heat, mustang, nitrous, pcv, remanufactured, supercharged, supercharger, superchargers, symptoms, vortech, zones
