SVT Forums
2.2L Kennebell
Old Oct 18, 2007 | 09:42 PM
ZO6AINTPOOP's Avatar
ZO6AINTPOOP
Default RE: 2.2L Kennebell
I have the cooling mod that prevents the overheating in cylinders 7 and 8 so that shouldnt be a problem and I also have a heat exchanger and a resovior to ice it down before I race
Old Oct 18, 2007 | 09:44 PM
mfj's Avatar
mfj
Banned
then ur set... sorry, i didnt think u did..... my bad!
Old Oct 18, 2007 | 10:17 PM
Fobra's Avatar
Fobra
Banned
from what ive seen the 2.2 make more power than the new version .. except maybe a little bit less than the 2.8... but the times seem about the same - and the 2.2 sounds badass... if you want more switch it up to whipple imo, or centri or turbo - but im baised
Old Oct 19, 2007 | 12:56 AM
AllVenom's Avatar
AllVenom
ORIGINAL: mfj
okay, but don't make me that promise too fast. and i guarantee u that u will never get 25 psi out of a 2.2 kb. maybe that is what u have read, but i doubt that u have the experience that i do. the 2.2 cannot boost 25 psi. Again, what cooling mods do u have?? Guarantee u the motor will not last long like that.
predictions:
cylinder #7 will loose compression from damaged piston caused by localized overheating or detonation in that cylinder
You must read a lot on svtperf. The cooling mod is not the great savior. If you have a detonation, nothing is going to save your pistons, no matter what kind of pistons your running. 20 psi is not the max out of a 2.2. I don't know where your getting your info from, but your wrong.
Old Oct 20, 2007 | 02:05 PM
spray175's Avatar
spray175
ORIGINAL: AllVenom
ORIGINAL: mfj
predictions:
Yea Ive definately seen KB 2.2's running more than 20psi.
Old Oct 20, 2007 | 03:27 PM
mfj's Avatar
mfj
Banned
yeah, show me a kennebell 2200 cobra with more than 20 lbs of boost! even dan's silver cobra, the fastest kennebell 2.2 in the country, was not more than 20 psi.
Old Oct 20, 2007 | 04:07 PM
spray175's Avatar
spray175
When we developed the BLOWZILLA 2200 (2.2L) kit, we felt it would satisfy 99% of our street/strip customers. Run 15-18 psi on the street and 19-24 psi at the weekend drags with race gas (octane depends on boost).
Old Oct 20, 2007 | 04:09 PM
spray175's Avatar
spray175
http://www.kennebell.net/techinfo/fo...RvsLYSHOLM.pdf
Old Oct 20, 2007 | 05:12 PM
mfj's Avatar
mfj
Banned
yes! i know what kennebell claims!!!!! Claims are not facts!! i have yet to see a kennebell 2.2 cobra with more than 20 psi! dont go by advertisements ppl!!
Old Oct 20, 2007 | 08:33 PM
spray175's Avatar
spray175
Lol you are the all knowing!! Kenne bell wouldnt claim it can run that much boost if it really cant. People would be damaging blowers all the time. But I know you can never be wrong about anything.
