SVT Forums
03 cobra heads
Old Nov 18, 2007 | 10:43 PM
mustangman36578's Avatar
mustangman36578
Default 03 cobra heads
i have a set of 2003 cobra heads that im going to be using for the cobra engine im building but i want to make this motor N/A at least for now because i dont have the money for f/i. i heard that these heads are set up for f/i. would an intake manifold from an earlier cobra fit these heads?
Old Nov 19, 2007 | 07:59 AM
Ellik's Avatar
Ellik
Default RE: 03 cobra heads
you'd need an upper and lower intake from a 99/01, but yes those heads will work N/A. Thats what the Mach I's have.
Old Nov 19, 2007 | 08:54 AM
Dan04COBRA's Avatar
Dan04COBRA
The Mach 1's & 03/04 heads are different.
Old Nov 19, 2007 | 09:40 AM
Ellik's Avatar
Ellik
how are they different other than the fact that Terminator heads had the priviledge of being installed by SVT? camshaft specs are the same, heads are the same.
Old Nov 19, 2007 | 10:31 AM
mfj's Avatar
mfj
Banned
mach 1 and 03/04 cobra heads are the same, cam profiles are different....
Old Nov 19, 2007 | 10:36 AM
Ellik's Avatar
Ellik
do you have the specs on the cams? It took me a while to sift through a bunch of crap, but what I was looking at showed the same lift and duration for both Mach 1 and Termy cams.
Old Nov 19, 2007 | 11:05 AM
mfj's Avatar
mfj
Banned
ur correct! the cams on all of the following cars, are the same: The Mach, Marauder, Aviator and 03/04 Cobra.
heads for the mach and 03/04 cobra are also the same.
The Mach 1's intake cams are basically the same ones found in the 5.4L Navigator engine, featuring specs of .394-inch lift and a 184 duration. The exhaust is more in line with the Cobra, with the specs coming in at 0.397-inch lift and a 196 duration figure.
Old Nov 19, 2007 | 11:39 AM
mustangman36578
so an upper and lower intake from a 99/01 cobra would fit the 03 cobra heads
Old Nov 19, 2007 | 12:03 PM
Ellik's Avatar
Ellik
correct.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
