SVT Forums
2001 SVT not starting
Old Mar 26, 2008 | 07:19 PM
stoveman60's Avatar
stoveman60
Default 2001 SVT not starting
2001 SVT 25,000 miles
has not been started in 1-2 months.Incovered garage. Ran fine last time it was run. Turned key, engine turned over. Would not start. Batt drained quick, went to clicking. Put a booster on and the engine turns but will not start.
I have a trickle charger on Batt now hoping it is just too low voltage.
Thanks for any help !!!
Old Mar 26, 2008 | 11:18 PM
MustangTitan's Avatar
MustangTitan
Default RE: 2001 SVT not starting
The same thing happened to my car awhile back... All i had was a corroded battery. Just get some battery cleaner (or diet coke) and clean it off... If its not corroded, i would still take the battery cable off and clean it alittle then tighten itback onreal good (it might just be loose) Thats the only thing i can think of if it was just sitting there for 2months with no problems before...I hope this helps. Good luck!
Old Mar 27, 2008 | 11:51 AM
1999SVTCTT's Avatar
1999SVTCTT
If its not the battery get somone in the car pop the good and open the valve on the fuel rail and take a pen and push it in and have somone try start it
if no fuel comes out ur fuel pump is out
Old Mar 27, 2008 | 08:28 PM
stoveman60's Avatar
stoveman60
Opening the valve on the rail with someone turning over worked. It took a couple of 15 second cranks and it finally started. Running fine and restarts fine now. Almost like the system needed to be bled ????
Thanks
Old Mar 28, 2008 | 01:56 AM
1999SVTCTT's Avatar
1999SVTCTT
looks like you were runing low on fuel lol got a litle air bubble =)
congrats tho
Old Mar 28, 2008 | 05:04 PM
stoveman60's Avatar
stoveman60
Short Lived...............Came home tonight and did the same thing. Finally started after 2nd try but ran real rough to start. Think I could have a leak of some sort so that the FI system is not holding pressure ????
Any thoughts
articman
Jun 21, 2018 11:45 PM
Luke9222
Oct 22, 2015 11:55 PM
97SN95GT
Sep 13, 2015 09:45 PM
Luke9222
Sep 4, 2015 06:46 AM
5.0 kevo
Sep 3, 2015 06:24 PM
