SVT Forums
Doing some modifications? Do I need a tune? Opinions??
Old May 24, 2008 | 02:59 PM
nxcess00's Avatar
nxcess00
Default Doing some modifications? Do I need a tune? Opinions??
Hey all...
Ok with everyones great advise and talking to my mechanic. I have come up with the following mods....
[ul][*]IRS Brace[*]Motoblue Hard Launch Cross Bar[*]Upper Pulley[*]BBK Throttle Body 65mm[*]Sub Frame Connectors[/ul]Possible
SCT or Diablo ... ?
Need to know what eveyone things about the combo and if I need a tune with these mods ?
Old May 24, 2008 | 03:48 PM
IROLLSALEEN's Avatar
IROLLSALEEN
Default RE: Doing some modifications? Do I need a tune? Opinions??
I would not use the bbk tb,accufab is by far the best.And you definetly need a tune with more boost. I use SCT and love it. the stock tune is way rich.Ford used four of five different tunes like early 03 did not have the stall fix and so on.Any tb will change your idle, you can control this by adjusting the tps but usually not enough.Mine had to be tuned for the tb, the pulley and other stuff.You will also have gains just from the tune, and get a dyno tune dont use the tune in a can..Just my .02 hope it helps.
Old May 24, 2008 | 04:17 PM
2k6silvergt's Avatar
2k6silvergt
I agree don't get the bbk. If you want one just go ahead and get the single blade accufab. And you will definitely need a tune. I use diablo for my tuning but you can't go wrong with diablo or sct. Just see what the person uses that you are looking to get the tune from.
Old May 24, 2008 | 04:36 PM
xxkazp3rxx's Avatar
xxkazp3rxx
You could do the accufab... or some other options are to keep it stock and port your blower/tb (sees almost exact same gains the accufab and ported tb)... or the billett flow one i heard it actually a lot better then the accufab...
Old May 24, 2008 | 07:33 PM
nxcess00's Avatar
nxcess00
ok thank you everyone! great help!
I just have to find a tuner in NJ....
Old May 27, 2008 | 09:19 PM
RuffCat's Avatar
RuffCat
def get a dyno tune done and not just a canned tune! The last 03 with a 15lb pulley that I seen on the dyno had a diablo chip crammed in his car and he was running a mere 50:1 a/f at peak. The kid picked up 72hp and upwards of 50ftlbs/tq just from dyno tuning.
mapitts
May 15, 2016 02:57 AM
Vrooom
Feb 21, 2016 05:25 PM
Oct 7, 2015 07:02 PM
firecoyote
Sep 27, 2015 02:37 PM
Mr. D
Sep 17, 2015 08:17 AM
