SVT Forums
Problemo
Old Sep 12, 2008 | 02:18 PM
cohhbra's Avatar
cohhbra
Default Problemo
so i got a new battery yesterday and got my electrical system checked out and everything works fine and the car drives fine, but when it sits for a long time without being on something is draining the battery slowly and i've looked at everything and everything is turned off. it just doesn't have enough juice to start but it runs all the lights on startup and stuff, i jus need to be jumped and it starts right up.
you guys ever had this problem or have an idea?
Old Sep 12, 2008 | 02:22 PM
McCloud's Avatar
McCloud
Turn it off and then go through each fuse on the block with the multitester and see which one is drawing current with ignition off.
Old Sep 12, 2008 | 02:39 PM
cohhbra's Avatar
cohhbra
yea, but it can't be anything serious can it?
Old Sep 12, 2008 | 02:40 PM
McCloud's Avatar
McCloud
It could be a failing CCRM which can be pricey. Could also be aftermarket alarm, bad ground, or some other unexpected issue.
Old Sep 12, 2008 | 08:45 PM
562cobra's Avatar
562cobra
loose ground cable??? it was the problem with my gt, just as you described it.
Old Sep 13, 2008 | 12:20 AM
the_camo_snake's Avatar
the_camo_snake
Also if you have a a bad alternator you may need a new one or one that puts out more amps. Get it all tested before any serious decision.
Old Sep 13, 2008 | 07:57 AM
mmafan's Avatar
mmafan
I recently had a 97 Cobra and had the same problems I did what McCloud said and checked every fuse with the car off..It worked like a charm...I never had a problem again...So I would try that 1st...
USN_rocko
Sep 2, 2012 12:19 PM
psi...kpa
Sep 21, 2011 08:58 PM
laterider
Aug 20, 2009 06:45 PM
Blacksmoke
Sep 22, 2008 06:12 AM
CUL8ER
Sep 2, 2008 03:34 PM
