cobra question
BraMas....I too have never heard of a 96-99/01 aluminum block actually "breaking" or "failing" either from big HP numbers.
I know the official reason SVT went to cast-iron was to increase torque potential of the 03/04 Cobras.....I can't find any news releases anywhere though that say they actually had any problems while testing (or even if they did testing) the aluminum block with a M112 on it. I thought I remembered seeing that back when they came out. You know what they say......the first thing to go is memory
My guess would be that they went with a cast iron block for a cost savings. Maybe the terminator project was getting to expensive and they had to find ways to save a penny.
I have no proof of this but I used to work in Automotive for 10 years and I've seen the OEM's do some pretty stupid things to save a penny
why does everyone want a crappy super charger. Those engine will not take it!!!
It will blow up if its not a 03 or 04 cobra just leave it alone. They rev hi and run really good with the bolt on stuff. You will have to drive the car easy with a power adder. If its just a street car do the suspension , brakes etc.. leave the super charger off. This will make the car faster and last longer. There is a reason why you dont see 500hp in saleens and roushes.They do more work on the suspension etc... When i did the spring, lower control arm and shocks in my 98 cobra it was so much more fun to drive and 3 times as fast on corner s than in stock form.
By the way did you look at the mach1? The solid rear will take way less $$ to make really nice. The irs sucks stock and will cost alot more $$ to make it better.
Ford didn't actually produce the Teksid they got it from a company... in italy, called teksid, who im pretty sure still makes blocks for ferrari, as i just posted in another thread, the reason for switching to the WAP block was it was much more cost effective, the italian blocks were just getting too expensive.
Nov 10, 2015 11:39 AM
