SVT Forums
Belt squeek
Old Feb 24, 2009 | 08:11 AM
lasco10's Avatar
lasco10
Default Belt squeek
i have an 04 cobra and whenever i start it the belt seems to squeek and its loud.... but it seems to go away as the car warms up. could this just be the belt or something more serious??
thanks
Old Feb 24, 2009 | 08:51 AM
antiv6's Avatar
antiv6
get a new belt, check and make sure all the idlers are tight, mine did that when one was so loose it was about to fall off. If belt doesnt fix it it may be a bad idler bearing
Old Feb 24, 2009 | 10:46 AM
Blackvenom01's Avatar
Blackvenom01
new belt!! they get dry and dry rotted which causes slippage which causes squeek....it goes away when the engine heats up cause the belt heats up and sticks more...like anti said if belt doesnt fix it check the tensioner which would cause the belt to be loose which squeeks over the pullies
Old Feb 24, 2009 | 11:17 AM
Timspony's Avatar
Timspony
SVT Section Moderator
...My Cobra did that when I bought it...replaced the belt and the problem was solved!
Old Feb 24, 2009 | 12:48 PM
antiv6's Avatar
antiv6
also i switched to a gatorback belt when this happened to my gates belt, i like it better
Old Feb 24, 2009 | 01:46 PM
lasco10's Avatar
lasco10
thanks guys sounds like a new belt is in order
Old Feb 24, 2009 | 02:09 PM
lasco10's Avatar
lasco10
what size belt should i get with a 3.1 pulley?
vargas
Jun 17, 2017 12:17 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
rafotree
Sep 22, 2015 03:55 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
