SVT Forums
New plans!
Old Mar 9, 2009 | 12:38 PM
  #101
pozesd99''s Avatar
pozesd99'
look forward to seeing this build. im doing something similar but not whipple for me, stupid f body's. im going a 300-400 dp nitrous setup
full spools sucks!!! i had one on my street car, it was rediculous!
martin you should get a shortened 9in like me and do a lil mini tub!
go all out!!! plus a 4-5k stall like me too
Old Mar 9, 2009 | 06:51 PM
  #102
mfj's Avatar
mfj
Banned
Originally Posted by SVTeeshirt
agreed.
MFJ stop being a ***** and tell me how much you paid for your 5.1 Set-up, and was it a 4.6- 5.1 conversion? or just the stright stroked block from livernois?
Its a stock 03 cobra block with a stroker crank. The block has been bored 20 over...
LMAO! My 8.8 should have no problems! JR cuts 1.2 60ft's on the same rear! And that's on a 10.5 tire!!!
At my hp level, lifting the front wheels is easy. The key is to keep your car from "bumper" standing, to get a good 60ft... You want the car lower...
I do need to have my torque boxes welded up though... :/
You don't need that kind of rediculous stall on a nitrous car. A tighter converter will do just as well, if not better on that kind of shot... On that kind of shot, you'll be going through bottles like CRAZY!
Old Mar 9, 2009 | 07:18 PM
  #103
mfj's Avatar
mfj
Banned
More on Converters for nitrous applications:
"Nitrous or supercharging also affect converter selection. An engine with one of these power adders produces more torque than it would if it was normally aspirated. That means a nitrous or blown engine needs a converter with a lower stall speed range. Otherwise, the converter will stall too high, causing it to slip and eventually self-destruct due to the extra heat generated."
Taken from: http://summitracing.com/landing/must...Type=5#FeatTop
NOTE THAT THIS DOES NOT APPLY TO TURBO APPLICATIONS... Where a larger stall will actually load the turbo faster...
Old Mar 9, 2009 | 09:11 PM
  #104
SVTeeshirt's Avatar
SVTeeshirt
how much was the machine work? to set the crank in the block and everything?
Old Mar 10, 2009 | 02:18 AM
  #105
Ehmark's Avatar
Ehmark
Dude let sleeping dogs lie, seriously you really are starting to appear immature. Just let it go and Let the guy run his own thread. There is way too much arguing and no where near enough tech info on the lsx swap : )
Old Mar 10, 2009 | 05:36 PM
  #106
mfj's Avatar
mfj
Banned
^Thanks....
mrtrodonet
Sep 19, 2020 03:12 PM
alan0614
Carolina Regional Chapter
38
Nov 30, 2015 09:24 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
wraith777
Sep 28, 2015 10:49 AM
