SVT Forums
cooling problems
Old Mar 19, 2009 | 12:08 AM
pcs's Avatar
pcs
fans turn on.
still looking for the problem
Old Mar 19, 2009 | 07:03 PM
Ehmark's Avatar
Ehmark
when the car is fully warmed up feel(carefully) diff parts of the radiator and tstat housing to see if any parts are still cold, if they are then somethings clogged. I have had brand new 180 tstats not work.
Old Mar 19, 2009 | 07:56 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Does the Cobra have heat??
Old Mar 19, 2009 | 09:44 PM
pitmitch910's Avatar
pitmitch910
burp the system, and get a new tstat mine ran real hot and then got a new cap and 180 tstat and fixed, filled it thru the cross over and let it run for a bit and checked it an it was fine
Old Mar 20, 2009 | 01:41 AM
pcs's Avatar
pcs
as in a heater?
im going to trying running it w/o a thermostat this weekend and fill it only from the cross over tube. i felt around all the hoses and they all seem to warm up equally. i feel deprived not being able to drive my cobra.
Old Mar 20, 2009 | 02:54 AM
Ehmark's Avatar
Ehmark
sounds like a burp problem or water pump.
Old Mar 20, 2009 | 12:04 PM
pcs's Avatar
pcs
hoping its a burp problem im having a not a water pump. my gt is 4 years older with the same pump and more miles with no problems yet.
Old Mar 21, 2009 | 04:00 PM
mfj's Avatar
mfj
Banned
Just curious, you're not trying to fill your cooling system by filling the reservoir, right? I hope you're not...
Old Mar 21, 2009 | 04:02 PM
mfj's Avatar
mfj
Banned
See that cap right in front of the driver side fuel rail, by the supercharger? Take a small ratchet to remove the cap, and fill it from there...
Old Mar 22, 2009 | 06:38 PM
mfj's Avatar
mfj
Banned
Any updates?
