SVT Forums
99 Cobra Running Lean
Old Apr 6, 2009 | 04:35 PM
99gt302's Avatar
99gt302
Default 99 Cobra Running Lean
99 Cobra is throwing up the p0171 and p0174 bank 1 and 2 running lean. I have a JLT Intake and bassani cat back with o/r x pipe.
I checked for obvious vac. leaks and found none. I cleaned the MAF earlier today and it seemed to run a bit better but still had the check engine light .I didnt clear it out after I cleaned the MAF, if that were the problem would it clear itself out?
It did go off by itself one time but came back on a few miles down the road. Any suggestions on what I could check?
Old Apr 7, 2009 | 06:31 PM
Blackvenom01's Avatar
Blackvenom01
i would pull your batterie for awhile and that will reset the code and see if it comes back on then..also do you have your car tuned for the O/R x pipe or did you just use eliminators
Old Apr 9, 2009 | 01:29 AM
99gt302's Avatar
99gt302
eliminators, but how would o/r x cause lean code? Thats after the 1st o2s which do the work for a/f
Old Apr 9, 2009 | 12:58 PM
OU8aCHVY2's Avatar
OU8aCHVY2
when did you install the cai? does it have a tune in it?
Old Apr 9, 2009 | 09:43 PM
MAD SVT's Avatar
MAD SVT
ya try the battery. you'll probably need to get a handheld and put a tune in it to accept the CAI, you can adjust your A/F
Old Apr 14, 2009 | 11:14 PM
99gt302's Avatar
99gt302
has a superchips(i kno ****ty) performance tune. Intake was installed when I bought the car...the fuel filter is looking pretty old so Imma try that.
Old Apr 16, 2009 | 11:42 AM
Fobra's Avatar
Fobra
Banned
Yeah you need a programmer to turn them off, the mils dont last long
Old Apr 16, 2009 | 01:27 PM
99gt302's Avatar
99gt302
Just got done changing fuel filter, damn that IRS subframe makes it a PITA to get to....cleared SES light by unplugging battery for about 5 mins and it hasnt been on after about 30 miles of driving, hopefully that old fuel filter was causing it, looked dirty as hell comming out of the filter, and you could tell it was a really old filter...maybe the stock one
Old May 16, 2009 | 10:57 AM
99gt302's Avatar
99gt302
still thoriwing the code, anyy suggestions?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Nov 10, 2015 11:39 AM
MusicCity615
Sep 12, 2015 07:05 AM
Sep 8, 2015 06:25 PM
Sparks_88
Sep 8, 2015 01:06 PM
