SVT Forums
2003 Cobra idling problem
Old Mar 6, 2010 | 09:49 PM
89GT351's Avatar
89GT351
Default 2003 Cobra idling problem
Hello everyone I recently bought my first 2003 SVT cobra. Everything is good except for the idling problem I am having. Here is what's it doing I use this car as my daily driver in the morning when I fire it up it would idle at about 1300 rpm which it should until the engine warms up and then it should go down to about 750 rpm right? well it does not do that not until I shut the car off and start it back up again then it idles as it should around 750 rpm. Once the engine is completely cooled it does it again I will have to warm the engine up and then shut it off and fire it back up and then it would idle just fine. I only had this car for about 4 days and it did that since the day I bought. It only has 9800 miles it does have Accufab throttle body, some unknown air filter, aftermarket radiator and intercooler everything else looks stock. Please someone help me. Thank you
Old Mar 8, 2010 | 04:42 PM
Blackvenom01's Avatar
Blackvenom01
ive heard many people having problems getting there aftermarket throttle bodies tuned good for idle...it also might not be tuned for that...i would find a tuner that could look at it for you and see where that idle is coming from....goodluck hope you love the new car congrats
Old Mar 8, 2010 | 07:34 PM
massmustang02's Avatar
massmustang02
Check your plugs too. They may not be gapped right. Also depending on the type they are, some have been known to cause rough idle. You should be around .028.
Old Mar 8, 2010 | 09:06 PM
89GT351's Avatar
89GT351
I am probably going to replace the spark plugs I just need to know what type do you guys recommend? I don't even know why would the previous owner change the throttle body? the whole engine is stock minus intake, throttle body, radiator, and intercooler I don't think that throttle body helps. I bought it from an older lady her husband used to drive it until he past away she just wanted to get rid of the car. Even with this idle problem I still love this car.
Old Mar 8, 2010 | 09:19 PM
mfj's Avatar
mfj
Banned
For your setup, NGK TR-6's
Old Mar 8, 2010 | 09:58 PM
massmustang02
+1. What I have for my setup.
Old Mar 9, 2010 | 10:41 PM
89GT351's Avatar
89GT351
I just ordered those spark plugs. This morning I took the idle control motor off and cleaned it a little bit and also wiggled some of the vacuum hoses I think it idles a little bit better, I don't know it might just need a good tune? Does anyone know a good cobra tuner near Louisville, KY?
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
