A little later I'm going to look at a 95 GT that has had a 1997 Cobra engine swapped into it. Full exhaust, looks decent. Only problem is that you can't read the computer. When you plug it into a code reader, it says "Error." What would cause this?
I would assume they did not swap the wiring for the OBD port. The 95 has OBD and the reader you are using probably is a OBDII reader. Just a guess on my part
