SVT Forums
Needing clutch advise
Old May 10, 2010 | 06:57 PM
redneck racer's Avatar
redneck racer
Default Needing clutch advise
Well its near time for a new one, and i have a few questions about it since this will be the first time its being changed. I plan to whipple/kennebell it in the very near future, should i go ahead and upgrade the clutch? or is that even necissary? Are any brands/makes better then others. I understand the saying "you get what you paid for" but im kinda trying to keep materials and install at around 800-1000 bucks if possible. I was quoted 800 from a well known local shop, and 1200 from the dealership but i believe thats with the basic stock clutch. Much thanks for any advice in advance.
http://www.lethalperformance.com/clu...bkpsrrhg5pjag5
Was looking around and found this, would it be overkill seeing as it says it can handle this much? the price between stage 4 and 5 is minimal. Are these decent, and what else would i need to buy with this kit. Whats the difference between 10 spline and 26 spline?
Old May 10, 2010 | 07:29 PM
99 GT vert's Avatar
99 GT vert
stock input shaft is 10 spline i toasted my single disc clutch in less than 5k miles with my kenne bell i would go dual disc if you plan to put a twin screw on it
Old May 11, 2010 | 05:44 PM
Impact 5.0's Avatar
Impact 5.0
Upgrade your input shaft.. I went with the McLeod RXT Twin Disc with flywheel and the clutch actually feels lighter then stock.
Old May 12, 2010 | 05:30 AM
Blackvenom01's Avatar
Blackvenom01
if your gonna upgrade your input shaft might as well just do the output shaft at the same time....i also agree going with a twin disk i have the spec super street twin...if you cant afford that the spec 3+ is very solid too and should hold your power
Old May 12, 2010 | 12:48 PM
Grabber's Avatar
Grabber
If you upgrade your Input shaft, you also HAVE to upgade your output shaft.
I would go with a Spec 2+ Clutch, with aluminum flyhweel, in a 26 spline. The install for the clutch, flywheel, the parts, the input and output shaft should run around 1500 bucks or so. However, you would pretty much have a bullet proof transmission and a very strong clutch.
djbigskrilla
Sep 20, 2022 01:04 AM
Jskeezy84
Sep 8, 2015 01:40 AM
Takeiteasee
Aug 27, 2015 03:59 PM
mweiland
Aug 16, 2015 10:59 AM
defarmer
Aug 13, 2015 06:40 AM
