Dose anyone know where to drill the oil return line for the turbo. I got a moroso race pan Its off the car so I just wanto go ahead and drill the lines
My stock oil pan is drilled right on the front for my procharger return line. Most aftermarket pans come with a pre supplied threaded drainback plugs im suprised the moroso one didn't.
Well you're only drilling a return line so as long as its placed high on the pan (as close as the block as you can reasonably get it) you should be fine.
