SVT Forums
solid rear end swap
Old Feb 27, 2011 | 09:00 PM
slidai's Avatar
slidai
Default solid rear end swap
I was thinking today, how would the alignment be effected with this swap? There is no need to alignment a solid rear end... at least the 05+ but i would assume an IRS would need to be aligned in the rear. I don't know of a way to tell the computer on the alignment rack that the car has a solid rear end other then just ignoring the back end.
Wouldn't this rear end swap change it quite a bit? Furthermore, if you have say 18x10 on the rear and 18x9 on the front, you couldn't rotate the tires anyway. Double trouble.
Anyone that has a rear end swap wanna weigh in on this?
Old Feb 28, 2011 | 03:07 AM
HEAVYMETALMATT's Avatar
HEAVYMETALMATT
You're correct on the offset rims and tire rotation, but having a solid axle makes alignment that much easier. You simply use the rear as your base, and align the front off of it. Too easy.
Old Feb 28, 2011 | 06:12 AM
slidai's Avatar
slidai
Here is another question about the solid rear axle.
I know the hangers would probably be different, but could you use the standard GT cat-back system since it's basically the same rear end?
Old Feb 28, 2011 | 07:31 AM
HEAVYMETALMATT
Yes you can. It's a straight swap. The only issue I had was the brake hoses. Took just a little bit of bending to get them to fit right.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
