Problem with tune (lots of code errors)
Hello there.
I'm from Spain and recently bought a 2010 v6 that already had the P0430 code (Catalyst System Efficiency below threshold, bank 2). Changed plugs, wires and lambda sensors and it's still there.
Got a SCT X4 for tune it and, despite the fact that my model should be preload tune supported, device said it wasn't. Once I contacted SCT they sent me preload tunes as custom files, and applied the 93 one (already proper gas in tank -EU 98 is the equivalent to US 93-), all was ok in theory. When i went for a ride, felt throttle wasn't responding properly so when arrived home I looked for codes and found a lot:
P0430 (my old friend)
P0600 (Serial Communication Link)
U0300 (Internal Control Module Software Incompatibility)
P2105 (Throttle Actuator Control System - Forced Engine Shutdown)
Seeing that mess, I dedided back to stock, and in theory it did, but car still feels bad, AND all those codes are still present!
I don't know if the problem is that there was already a tune when bought the car, but aftermarket parts were removed (all parts seem to be stock) or if the PCM/ECU is or was damaged...
Any clue of what could be the problem and what could be the solution?
Thanks in advance.
Thanks in advance.
Nope for tune.
But at least I could fix the P430. It seems previous owner closed EGR valve so I got new one and cleaned one of the catalytic converters that seemed to be a bit stuck = error gone.
ECU got too a factory update. No issues with that.
Tried tune before that but got the exact same problems, so I guess the problem is with SCT pre-loaded tunes.
I'm getting a 2014gt in 2 weeks so I don't care anymore with this particular issue.
05MineralGrayV6
Jun 26, 2012 05:38 PM
