OVERDRIVE!!!
Old Apr 14, 2006 | 04:31 AM
  #21
ByPopularDemand's Avatar
ByPopularDemand
Default RE: OVERDRIVE!!!
I dont see how o/d off isnt better for racing. With it off you run in higher rpms, so wouldnt you be making more power
Old Apr 14, 2006 | 04:42 AM
  #22
product1620's Avatar
product1620
Ok, i'm going to completely ignore most of the above posts. In every auto/od car iv'e been in the od works in every gear at any speed. if your cruising with it off and then switch it on the rpms will drop. If your cruising with it on and you switch it off then the rpms will rise. This will happen no matter what gear you are in, or how fast you are going. So to get the the most power to the ground at take off you will want it off.
Old Apr 14, 2006 | 05:39 AM
  #23
93BlackNotch's Avatar
93BlackNotch
WTF!!! This is like talking to a brick wall... Put your car in 1st gear, drive with it at 3000 rpms, play with the overdrive switch all you want and nothing will happen.... Put the car in D, do 45 miles per hour, floor it and see what happens, it will downshift to the lowest possible gear for the speed you are doing... OD is only activated when you are at a cruising speed with a steady throttle, once you floor it, OD deactivates and the transmission downshifts....
Whatever, you guys put it in whatever gear you want, I know nothing, I've only owned 6 Mustangs, and have been racing them for 10 years....
Old Apr 14, 2006 | 11:42 AM
  #24
mustangman02232's Avatar
mustangman02232
the 4R70 tranny wont shift into OD at WOT, turning it off does absolutley nothing but lock you out of 4th gear,
Old Apr 14, 2006 | 02:16 PM
  #25
alexr's Avatar
alexr
ORIGINAL: 93BlackNotch
even so, what makes you think im (we're) gonna trust what you say over the people that ive seen giving quality and accurate advice on these subjects for the past year?
ive been reading what people have been saying for the past year, and their information has seemed way more accurate than yours.
plus your avatar is really gay.
Old Apr 14, 2006 | 03:06 PM
  #26
93BlackNotch
Ok, you do what you want... I'm done trying to help...
Edited to be polite....
Old Apr 14, 2006 | 03:08 PM
  #27
zarins04stang's Avatar
zarins04stang
cmon guys, we all kool here, all this is is a discussion
Old Apr 14, 2006 | 06:47 PM
  #28
mustangman02232
ORIGINAL: zarins04stang
no kidding but this post has exploded to just say its a god damn overdrive button that just shuts the car out of overdrive and does nothing else.
Old Apr 14, 2006 | 06:49 PM
  #29
Derf00's Avatar
Derf00
Gentleman's Relish
**** you all and just buy a manual tranny [8D]
Old Apr 14, 2006 | 08:28 PM
  #30
ByPopularDemand
So the raised RPM's mean nothing
