OVERDRIVE!!!
Old Apr 13, 2006 | 03:41 AM
zarins04stang's Avatar
zarins04stang
Default OVERDRIVE!!!
Can someone pleaseeee fill me in on wat the Overdrive does? when do u use it? and do u get better mpg with it on or off?
Old Apr 13, 2006 | 03:47 AM
93BlackNotch's Avatar
93BlackNotch
Default RE: OVERDRIVE!!!
Leave it on... It does nothing if you have the go pedal down...
Old Apr 13, 2006 | 03:56 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: zarins04stang
Overdrive is another gear. It's for milage more than speed.
Old Apr 13, 2006 | 04:05 AM
alexr's Avatar
alexr
(atleast on my car) when i have the overdrive on, it knocks my rpm's down on average 1000rpms, hence saving me probably a lot of gas.
Old Apr 13, 2006 | 08:51 AM
mustangman02232's Avatar
mustangman02232
less then 50 mph turn it off, more turn it on
Old Apr 13, 2006 | 09:57 AM
hookedonkronik's Avatar
hookedonkronik
overdrive is meant for cruising at higher speeds hence higher rpms like say on the highway. You'll be driving say at 3000 or 3500 rpm, throw (o/d off) on and watch the rpm's drop which will save you on gas because the engine is doing less work
Old Apr 13, 2006 | 12:14 PM
alexr's Avatar
alexr
ORIGINAL: mustangman02232
not if youre not worried about how fast you accellerate. i dont know about other cars, but i can sometimes see my overdrive kickin in as low as 35mph.
Old Apr 13, 2006 | 02:02 PM
mustangman02232
ORIGINAL: ARdoller
yes it goes in around 35, but its always shifting between third and O/D so unless i go over 50ish i usually just turn it off
Old Apr 13, 2006 | 02:23 PM
Jugador's Avatar
Jugador
if you have a steady foot it shouldn't downshift (unless there's a crapload of wind or something)
Old Apr 13, 2006 | 03:01 PM
ByPopularDemand's Avatar
ByPopularDemand
ORIGINAL: hookedonkronik
I cruise the freeway at about 2grand. If i kill the o/d it goes up to about 3 grand
