OVERDRIVE!!!
Old Apr 16, 2006 | 01:20 AM
  #31
jthorn9's Avatar
jthorn9
The Godfather
Default RE: OVERDRIVE!!!
Now to correct some more bad info here. If you floor the car with od on, it won't downshift into the last gear, it continues out the gear you're in. Now if you just hit the gas, then your gear will take forever to shift out, it's only when you go part way down, let your engine rev up, then floor it that the car actually takes off. Trust me, I've got this down. But normally, I will just turn off the OD so that I can just floor it and go, because it will grab the last gear pretty hard with the OD off as oppossed to on.
Old Apr 16, 2006 | 01:26 AM
  #32
03YellowPony's Avatar
03YellowPony
ORIGINAL: jthorn9
That's where you are wrong. When I HAD my Stang, if I was in OD and floored it, it would downshift to the gear it wanted.
Old Apr 16, 2006 | 01:32 AM
  #33
jthorn9's Avatar
jthorn9
The Godfather
Mine sure in the hell doesn't, it continues through let say third gear, then shifts into 4th. I never downshift when I floor it.
Old Apr 16, 2006 | 04:07 AM
  #34
03YellowPony
ORIGINAL: jthorn9
That's the dif between an auto and a manual
Old Apr 16, 2006 | 05:01 AM
  #35
ByPopularDemand's Avatar
ByPopularDemand
ORIGINAL: 03YellowPony
ORIGINAL: jthorn9
Did having the OD off still raise your rpm's
Old Apr 16, 2006 | 05:38 AM
  #36
03YellowPony
ORIGINAL: ByPopularDemand
ORIGINAL: jthorn9
Only when it kicked out of OD
  #37
Jugador's Avatar
Jugador
ORIGINAL: jthorn9
would that have anything to do with the diablo?
Old Apr 16, 2006 | 05:39 AM
  #38
03YellowPony
ORIGINAL: Jugador
ORIGINAL: jthorn9
Absolutly nothing.
CarrieS
Sep 1, 2015 01:00 PM
erig94gt
Jun 11, 2005 03:14 AM
BlackGT5.0
Feb 15, 2005 01:05 AM
89stanglx
Feb 3, 2005 11:17 PM
88_5.0
Dec 24, 2004 04:17 AM
