Heads
Old May 6, 2006 | 09:10 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Heads
So from what im learning our stock heads suck. How much hp would I get after a port and polish
Old May 6, 2006 | 09:27 PM
HRnB's Avatar
HRnB
Administrator
Default RE: Heads
Our heads are strong, but they are choked down by Ford. If you go to a big valves and cam, you can get the same HP increase as adding a blower. You can buy a stage 3 from SSm ready to install kit for around 1500 bux. It's the same set up they run in their 10 second V6. I personally like the SSM stuff.
Old May 6, 2006 | 09:53 PM
ByPopularDemand
Default RE: Heads
So I need bigger valves then
Old May 8, 2006 | 10:34 AM
Lancerzor's Avatar
Lancerzor
Default RE: Heads
wait what? a 10 sec V6?
Old May 8, 2006 | 01:58 PM
ByPopularDemand
Default RE: Heads
Yeah on supersix, that is the head and cam package I need. Time to start saving
Old May 8, 2006 | 02:28 PM
HRnB's Avatar
HRnB
Administrator
Default RE: Heads
In my opinion, and I'm sure every V6 owners opinion, the SSM stage 3 package is the way Ford should have done it from the start. Because of the fact that the stage 3 is giving a 99-04 V6 around 280hp N/A, your not stressing your engine the way you would with forced air on a stock V6 top end. BUT, if you do a stage 3 and forced later, you have a V6 monster.
Old May 8, 2006 | 02:30 PM
ByPopularDemand
Default RE: Heads
Yup I see heads cam and a few other boltons. Then maybe spray
Old May 8, 2006 | 03:38 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Heads
The heads and cam should be more than enough for you, I don't think you'll need any juice, just make sure you remember to get new fuel injectors and to make sure you have a shop reset your air to fuel mixture, you ecu shoud do it automattically, but just make sure everything is fine.
Old May 8, 2006 | 10:40 PM
ByPopularDemand
Default RE: Heads
Yeah I forgot to mention the tune, and the spray will be my just incase
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
