A/C electrical issues
Old Jun 8, 2006 | 01:03 AM
Physics's Avatar
Physics
Default A/C electrical issues
My girlfriend has a 98 3.8L, and the air conditioning stopped working one day awhile back. I finally got around to tracing the electrical system with the help of a service manual CD. Everything appears to point to the constant control relay module being bad. The fans and fuel pump work fine, so I know the ground is good on it. Pins 21 and 22 have +12V on them, so pin 23 is supposed to have +12V as well. This is the output to the a/c clutch field coil, but it just sits at .13V whether the a/c switch is on or off. When I connect +12V to pin 23, the a/c works and blows really cold. I found a junkyard specializing in Ford parts here and got a replacement from a 97 3.8L today. When I installed it, though, I had the same problem. There is the possibility that the replacement module has the same problem, but I do not know how common CCRM failure is on these cars. More than likely, it is probably something else in the electrical system, but I have been unable to locate anything so far. Any ideas?
Old Jun 8, 2006 | 01:11 AM
03YellowPony's Avatar
03YellowPony
Default RE: A/C electrical issues
ORIGINAL: Physics
You sure it's just not low on refrigerant? If it gets too low, the low pressure switch trips and won't allow the compressor to engage.
Old Jun 8, 2006 | 03:26 PM
Physics's Avatar
Physics
Nevermind, I replaced the CCRM with another one, and it works perfectly. Thanks for the suggestion, 03YellowPony.
vargas
Jun 17, 2017 12:17 PM
LiquidDrink
Sep 29, 2015 10:06 AM
SteelerNation82
Sep 16, 2015 07:11 AM
TfcCDR
Sep 14, 2015 12:08 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
