Tires
Old Jun 11, 2003 | 09:51 AM
Lil'stang's Avatar
Lil'stang
Default Tires
Hi,
I recently took the stock rims and tires off my 02 V6 'Stang. I put 17" rims with low profile tires on. The tires were used before I got them, but are still in great shape. The problem is that the car now pulls to the left and ride side, I tried rotating them around, but still have the problem. I had my cars front end aligned about a month prior to buying these tires so I don't think thats the issue. Also, the tread on these tires are very loud! When I hit 80 - 90 I have to crank the system not to go crazy.... any advice would be greatly appreciated.
Thanks
- J
Old Jun 26, 2003 | 12:31 AM
Milburn01's Avatar
Milburn01
Default Tires
... dude... try puttin the same amount of air pressure in each tire.. that helps alot.. and if that doesnt work.. get a allinment..</P>
</P>
Old Jun 26, 2003 | 06:07 AM
knupxfon's Avatar
knupxfon
Default Tires
Jack you your car up and spin the tires. Make sure the tire doesn't look like its wobbling. Since they were used the steel belts in them could be warped or broken. It's not gonna blow out, but it will make your car pull and wobble, and ride loud.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
