Cost to install a new underdrive pully
Old 08-30-2006, 01:11 AM
HornyHornyHippo
HornyHornyHippo's Avatar
Default Cost to install a new underdrive pully
So, i was looking into getting a new underdrive pulley since they are only like 200 bucks including the new belt. However one of my friends told me installation could be pricy because they might have to take off the front end to put it on. First off, is this true, and how much about would you say it would cost to put this part on? OR is this somthing i could be doing myself?
HornyHornyHippo is offline
Old 08-30-2006, 01:14 AM
NoChanceMRP
NoChanceMRP's Avatar
Default RE: Cost to install a new underdrive pully
Shouldnt be pricey at all. I've never done it, but I've got 2 family members with Mustangs who installed it very easily. They're gonna help with mine when it comes in.
NoChanceMRP is offline
v6inva
v6inva's Avatar
its free...well kinda
its pretty easy to install dude and you dont have to take off the front end...wtf
theres a bunch of how-to's on udp installs floating around, search for them
v6inva is offline
Old 08-30-2006, 01:15 AM
Verado
Verado's Avatar
You dont need to take off the front end. You need a special tool to take the pulleys off.
Verado is offline
Old 08-30-2006, 01:25 AM
africkanV6
africkanV6's Avatar
how much does the tool cost and are UDPs worth it?
africkanV6 is offline
Old 08-30-2006, 03:05 AM
joecool2126
joecool2126's Avatar
Hotrodz already did the foot work. https://mustangforums.com/m_1238175/...tm.htm#1238175 I can't thank enough for all the pictures. very helpful.
joecool2126 is offline
Old 08-30-2006, 03:37 AM
africkanV6
africkanV6's Avatar
the link doesnt work......
Old 08-30-2006, 05:30 AM
03YellowPony
03YellowPony's Avatar
It only cost me like $65.00 to get mine installed. And NO you don't have to take off the front end. It only takes like an hour of labor time to do it. And I had 2 pulleys and the belt.
03YellowPony is offline
Old 08-30-2006, 12:34 PM
hookedonkronik
hookedonkronik's Avatar
How many underdrive pulleys does an sn95 mustang have? 2?
And is a flywheel different from a pulley? When i look at the entire serpentine system of belts it looks like there are about 3 pulleys. And for flywheels, i hear you can get a good one that only takes something like 15 hp to get rotating opposed to the stock one which takesa bout 40 hp...
Anyone do this and know how long install is for one?
hookedonkronik is offline
Old 08-30-2006, 12:49 PM
Jefferson
Moderator
Jefferson's Avatar
The underdrive pulley is a smaller replacement for the crank pulley, which is located at the lowest point of the belt and is the largest of the pulleys. There is only 1 crank pulley.
The Flywheel is what the clutch pushes up against and has nothing to do with the pulley system. You can get a lighter flywheel which can help acceleration.
I am unsure how long the flywheel install will take but the tranny will have to be dropped. The underdrive pully install is simple and shouldnt take more than an hour.
Jefferson is offline
Quick Reply: Cost to install a new underdrive pully
