Hydrolock
Old Nov 18, 2006 | 02:53 PM
boardlockmango's Avatar
boardlockmango
Default Hydrolock
I think my car hydrolocked but i'm not sure. I got hit with a flood here in NY and my car stalled and won't run. All it does it crank over...If it is hydrolock how do I fix it? If anyone could help me that would be awesome. Thanks.
Old Nov 18, 2006 | 03:12 PM
BeachStang04's Avatar
BeachStang04
Default RE: Hydrolock
Best thing i know to do is let it sit, only time will tell. But about 80 percent of the time if its hydrolocked ur ****ed...
Old Nov 18, 2006 | 03:46 PM
HRnB's Avatar
HRnB
Administrator
If your engine did ingest water and it was hydrolocked, it wouldn't turn over. You said it cranks over, so it's most likely electrical. As mention, just letting the car sit for a while usually works because the problem area dries out. As soon as you can, I suggest replacing old spark plug wires, rubber boots and depending on the year, examine your coil for cracks. Also, you can buy a silicone spray that you can spray on all of you ignition wires etc to repel water.
By the way, if you ever feel that your car is hydrlocked after you go through a flood, don't keep trying to crank the engine because you will cause serious damage. Always remove your sparks and then crank it over to blow out the water first. Then start the process of drying things out.
Old Nov 22, 2006 | 07:28 PM
boardlockmango
Well I took it to the shop to get it fixed because after three days it still didn't start.
So I got an Oil Change all new spark plugs and wires, the bottom half of the spark plugs were broken off (awesome) and my compression test was 75 haha. There was an enormous amount of water in the engine so they cleared it from the intake and everything else. Other than that, it's great! So finally I have my car back!
pinto18
14
Nov 10, 2008 11:29 AM
Jim H.
Apr 27, 2008 01:45 AM
97snakebite
17
Dec 15, 2007 03:09 AM
GTTang
Nov 8, 2006 02:35 AM
helpingafriend
Feb 4, 2006 09:34 PM
