The Big Wish List Post
Old 12-26-2006, 11:17 AM
Rook6
Rook6's Avatar
Default The Big Wish List Post
What will everyone's completed long-term builds contain? I like to think ahead.
Suspension/Handling
04 Cobra Independant Rear Suspension (don't they make a strut brace for this too?)
Maximum Motorsports IRS Grip Box (bushings, end links, C/C plates,the works)
Maximum Motorsports Tubular K-Member/Control Armspackage
Coil-Over Conversion (Front, maybe rear)
Tokico D-specs, all around
Kenny Brown Full-Length Subframes and Matrix System w/ Jacking Rails
BBK Strut Brace
Solid, Center-drilled Steering Shaft
Brakes
13"(only if 14" won't fit) Front Brake Package (Steel Braded lines and all)
Brake Proportioning valve
Drivetrain
Eaton LSD
Lightweight Driveshaft (Aluminum...carbon fiber...might even stay with stock material depending on research)
Lightweight Flywheel
Spec Stage 2 or 3 Clutch
Steeda TriAx
T-5 Dogtooth Conversion. (If I can't find a sequential 6-speed that'll fit....Quaife...hello?)
Don't know if I should stick with 3.55s or go back to 3.73s
Engine
SSM Stage 3 w/Install Kit
All Forged 3.8LRotating Assembley
Morana V6 RacingStud Girdle
Boost
Twin Turbo Setup (Maybe TMA but probably just a custom setup with twin 18Gs...more research needed)
Boost Controller, Wastegate, BOV,Turbo Timer, etc.
Extras
G-Force Computer
Goodyear Tire Pressure Monitoring System(cheaper than you'd think)
Visual
PMP 05 Front end conversion
Z3 Fenders (yeah yeah....trust me, it'll work)
Steeda Cowl Hood w/Louvers
18x9 (maybe staggered 18x10) Steeda Ultralights.
"NO FLYBY" brakelight decal (already have this...and I love it)
Might tint it.
On the fence about lambo doors and a billet fuel door.
Rook6 is offline
Old 12-26-2006, 11:37 AM
NvRdoNeStAnGsIx
NvRdoNeStAnGsIx's Avatar
Default RE: The Big Wish List Post
So when you die, will you finish this project in the next life or the one after that.. lol.
NvRdoNeStAnGsIx is offline
Old 12-26-2006, 11:53 AM
Rook6
Rook6's Avatar
Actually, I was doing the math one day. It should only take me 2 years at the longest, probably much less depending on how many deployments I go on.
Rook6 is offline
Old 12-26-2006, 12:54 PM
jthorn9
The Godfather
jthorn9's Avatar
My short term goals are:
Intake
1.) Granatelli Chrome 90mm Mass Air Sensor
Engine
1.) BBK High Flow Fuel Regulator
2.) Holley 155lb Hr. Fuel Pump
3.) BBK High Flow Fuel Rails
Tansmission
1.) G-Force T-5 Upgrade Kit
Driveline
1.)Detroit True LockLimited Slip Differenital
2.) A new set of 3.55 Gears
Exterior
1.) Urathane Saleen Body Kit
2.) Fiberglass Saleen Hood
4.) New Saleen S-351 Wing
5.) New Custom Paint Job (restoring yellow) with the engine block beingpowdercoated silver
6.) 17" Saleen Replica Rims
7.) Vertical Door Kit
Interior
1.) Vinyl Rear Seat Delete
2.) Satin Gauge Face Cover
Engine Bay Dress Up
1.) Polished Overflow Tank
2.) Polished Over Flow Tank Mount
3.) Polished Battery Box Cover
4.) Ford Racing Valve Covers
Long term goals:
11" Cobra Break Kit
347 Forged Stroker Kit or a Crate 351W Engine
9 PSI Polished Vortech Supercharger
Larger, more show gradeaudio set up
jthorn9 is offline
Old 12-26-2006, 02:57 PM
amrcnidyot
amrcnidyot's Avatar
mine will take a little longer..at least for me it will, it will actually probabaly never happen.
exterior:
03 cobra front bumper
new mach 1 chin spoiler
put mach grill delete on cobra bumper
hid fogs and headlights
mach 1 shaker hood
03 cobra rocker panels
new window tint
mach 1 rear window louvers
03 cobra rear w/ mustang instead of cobra written in it
clear corner tinted headlights
satin black rear spoiler
targa top
Interior:
cobra front and rear seats
mach 1000 system look alike w/ aftermarket parts...havent really looked into this yet.
bullit dress up kit.
suspension:
already have strut tower brace and roush springs
8.8" rear end w/ 4.10 and detroit
tubular k-member
steeda front and rear sway bars
subframe connectors
adjustable shocks/struts
cobra brakes all around
Drivetrain:
frpp aluminum drive shaft
rebuilt trany w/ shift kit
higher stall tq converter
like i said above, 4.10 and detroit
Engine:
ssm 4.3 stroker kit
ssm stage 3 powerpack
bbk tb
higher flow fuel injectors
high flow fuel pump
new fuel lines
battery moved to trunk
twin prochargers at 11 psi. both intercooled..they come that way.
new radiator
im sure there is a lot more but i cant think of it right now.
amrcnidyot is offline
Old 12-26-2006, 06:04 PM
flash20
flash20's Avatar
ORIGINAL: jthorn9
Intake
Engine
Tansmission
Driveline
Exterior
Interior
Engine Bay Dress Up
Long term goals:
11" Cobra Break Kit
jthorn WTF are u okay?
flash20 is offline
Old 12-26-2006, 06:25 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Hmmm, let's see
SuperSix Stage 2 haeds & cam pkg
SuperSix ported & polished intake
Remove N2O
Purty stuff all over the engine and interior
I've already got a lot done, it's these last few things that I need to build up my savings again for.
Ryan
RyansQuick6 is offline
Old 12-26-2006, 09:40 PM
v6stang07
v6stang07's Avatar
exterior:
hood scoop black with custom black stripe on the hood to match
cobra side scoops
newer 2 post spoiler black
rear honeycomb panel
03-04cobra rear, shaved
window tint
some interior billet and engine billet
performance:
power pack, stage 2
cai
udp
4:10's
lsd
tuner
v6stang07 is offline
Jb145700
08-21-2022 06:37 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
robjh22
Suspension
09-08-2015 12:47 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: The Big Wish List Post
