Problems after overheating
Old Jul 31, 2003 | 11:44 AM
Kmitch1985's Avatar
Kmitch1985
Default Problems after overheating
I drive a 93 2.3L N/A
The other day I lost my water pump and over heated. It was a bad thing. I've changed my pump, oil, spark plugs, wires and PCV valve. The engine cranks and runs good until it warms up then the RPM's fall off while idling at a stop, or while in park and the engine wants to die. I don't think its a vacuum leak, my engine doesn't run ruff, and if I turn my AC on the RPM's pick back up (I think thats the computer compensating for the workload). The temp gage reads on the cooler side and the engine runs smooth while driving.
I'm perplexed, any ideas? Is there any way I could have fried one of my sensors. If so anyone know a simple way I can check it out. I suppose I could take it to a shop and let them diagnose the problem, but to be honest the mechanics I know wouldn't know any more than I do in figuring out this problem. The only difference is they would be charging me by the hour and that wouldn't be any fun.
Speaking of sensors I tried looking up information about the Engine Coolant Temprature (ECT) sensor. All I could find was the circuit diagram. Anyone know what it looks like or where it is located?</P>
Old Aug 1, 2003 | 12:49 AM
vfast's Avatar
vfast
I ♥ Acer
do a compression test...did you have the head checked?..
Old Aug 11, 2003 | 11:27 AM
knupxfon's Avatar
knupxfon
you can get your computer codes read for free at autozone.
Old Aug 11, 2003 | 09:51 PM
Buzzstang's Avatar
Buzzstang
was there any water in your oil when you changed it? have you checked it after you change it and drove for a while/
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
