BUMPER
Old Feb 26, 2007 | 06:25 PM
stang_girl_03's Avatar
stang_girl_03
Default RE: BUMPER
ok guys it is a back bumper and i can and will do it BY MYSELF lol...anyways can anyone give me directions...if not i will post up in the 4.6 section so i can get some help from somewhere
Old Feb 26, 2007 | 07:35 PM
flash20's Avatar
flash20
Default RE: BUMPER
greg just offered to help, yall are friends so meet up install ur bumper, then take pics of both cars
Old Feb 26, 2007 | 07:55 PM
stang_girl_03
Default RE: BUMPER
thanks for the help [>:]
Old Feb 26, 2007 | 08:07 PM
mvr's Avatar
mvr
Default RE: BUMPER
maybe if you or a buddy has a haynes, chilton or ford tech manual it will tell you how to install a rear bumper. i used to have a ford tech manual for my last car (contour) and it told you in detail how to take off any part you wanted.
Old Feb 26, 2007 | 08:41 PM
Baron von Munchausen's Avatar
Default RE: BUMPER
Can't believe no one just gives somedirections instead of B.S., actually though I can believe it. Remove your trunk trim panels, remove the seven bumper cover attachment nuts inside the trunk, remove fuel overflow drain hose, remove four bumper cover screws in the wheel wells, and the five push pins along the bottom of the bumper cover.
Hopefully your replacement bumper cover includes the metal attachment bracket for the trunk mounting nuts, and the side reflectors. If it does not, you must remove yours from your existing bumper and transfer them to your replacement bumper.
I have done this mod on an '04 V6, and it's not overly difficult. Good luck.
Old Feb 26, 2007 | 08:50 PM
stang_girl_03
Default RE: BUMPER
ORIGINAL: Baron von Munchausen
how long did it take??
Old Feb 26, 2007 | 08:56 PM
Default RE: BUMPER
Two hours, and I had to reomove the bracket/side markers to whichI referred. The bracket is riveted to the bumper cover, and that's why you hopefully will have one included already with the replacement cover. If not, drill out the rivets and re-install on the GT cover with (preferrably) a pop rivet tool or use small bolts and nuts.
Old Feb 26, 2007 | 09:03 PM
stang_girl_03
Default RE: BUMPER
thanks so much!
Old Feb 26, 2007 | 09:04 PM
Default RE: BUMPER
No problem, and good luck
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
winner99
Oct 1, 2015 01:06 PM
Sparks_88
Sep 8, 2015 01:06 PM
