2 wheel burnout?
Old Feb 28, 2007 | 12:54 AM
nozracer's Avatar
nozracer
Default 2 wheel burnout?
Ive notice that v6's cant do a burn out with both wheels only one, what do i need to do a 2 wheel burn out. And how do i go about installing it and does it improve perfomance
Old Feb 28, 2007 | 12:55 AM
GregoryA44's Avatar
GregoryA44
Default RE: 2 wheel burnout?
an lsd, a t-lok or true trac
Old Feb 28, 2007 | 12:56 AM
Xemeth's Avatar
Xemeth
You have an open differential in the rear end, which only gives power to one wheel.
In order to use both wheels, you need a limited slip differential, or LSD. A Ford T-Lok is the cheapest but not the best if you plan on over 225rwhp or more.
And it doesn't improve performance as far as HP or torque, it just makes both tires spin instead of one.
Old Feb 28, 2007 | 12:57 AM
Xemeth's Avatar
Xemeth
ORIGINAL: GregoryA44
There's a lot more than just those...
Old Feb 28, 2007 | 01:01 AM
nozracer's Avatar
nozracer
how much do these come out to? and how do you install them?
GregoryA44's Avatar
GregoryA44
yea but im tired and didnt feel like writing them all out
Old Feb 28, 2007 | 01:04 AM
raz54's Avatar
raz54
ORIGINAL: Xemeth
True, it does not give you more HP ot TQ but it does improve over all performance. It gets you off the line much quicker because both wheels are pushing instead of one just spinning so your ET will drop with an LSD.
Old Feb 28, 2007 | 01:29 AM
forplay's Avatar
forplay
hey nozracer look at post "What is the difference" It has several links for several options.
Old Feb 28, 2007 | 01:39 AM
tommy2273boy's Avatar
tommy2273boy
ORIGINAL: nozracer
for Gears,LSD,Bearings Kit about $500 or get slightly used ones for $300ish
and install is done by pros for $250
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
