lowering question
Old Mar 17, 2007 | 03:25 AM
tims 88 4's Avatar
tims 88 4
Default lowering question
hey yall i got a question about my car ima be lowering her soon and i know i need to get caster camber plates if lowered 1.5+ inches but i was also woundering if u should get adjustable uca and lcas to adjust the pinion angle of the drive line would it helpwith stress on the srive shaft and everything else
Old Mar 17, 2007 | 04:59 PM
tims 88 4's Avatar
tims 88 4
Default RE: lowering question
any help
Old Mar 17, 2007 | 06:30 PM
raz54's Avatar
raz54
From what I was told you don't need CC plates unless you drop it over 1.5" and I've never heard anything about said about pinion angle.
Old Mar 17, 2007 | 06:51 PM
Jugador's Avatar
Jugador
i wouldn't be super worried about pinion angle, but in any case, you really only need adjustable uppers to properly adjust pinion angle. solid lowers will be fine.
Old Mar 17, 2007 | 07:15 PM
blackout01's Avatar
blackout01
[sm=WTFsgign.gif]no offense, lol but i honestly thought i was reading a foreign language
Old Mar 17, 2007 | 07:47 PM
Jimmz's Avatar
Jimmz
Dude all you need to do is install springs, shocks/struts, maybe cc plates and get an alignment....
Old Mar 17, 2007 | 09:38 PM
i_drive_stangs's Avatar
i_drive_stangs
hey i feel you on this once you lower it you will only need adj. upper control arms solid lowers will be perfect. upr products sells a badass kit that comes with a sway bar adj. upper and lower control arms. you can find it for like $450. once you have adj. upper conrtol arms look at the pinion angle (while it is on the ground not hanging the air.) and see wich wat it needs to be adj. remember to factor in the how the car will hunker down when you are going down the track. you want it to be as strait as possible so that there is no binding. wow i hope i am helpin you not sure if this was even what you are askin. hope i helped.
Old Mar 18, 2007 | 12:36 PM
tims 88 4's Avatar
tims 88 4
you guys are actually helpin alot and im thinking about gettin cc plates before i lower it cuz i just had the front end aligned and he could barely get it into specs so its all outta wack and i need to do something about it
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
