porting the lower intake
Old Mar 30, 2007 | 02:09 PM
cisurfer's Avatar
cisurfer
Default porting the lower intake
i just got my intake manifolds today and im going to be porting the lower to use with the eaton m112........when i look in the runners in the lower there are liek black caps with a hold in the center in each runner....anyone know what this is
Old Mar 30, 2007 | 02:31 PM
jovez's Avatar
jovez
Default RE: porting the lower intake
those are the EGR ports. you can grind them down and fill them in to delete or just leave them there. Here is what RPMmustangs does.
What i did with mine is i grinded them down, but those ports collapse and cause a hole the size of the whole "bump" so you gotta fill them in and regrind them down. Good luck.
Old Mar 30, 2007 | 03:59 PM
LilRoush's Avatar
LilRoush
I left mine in for emissions passing.If you delete them, you also need to have the EGR valve closed and the ECU modified to accept that system being taken off line. Otherwise you'll run rich when the valve opens to recirculate the exhuast gas. Running that rich over time will fowl out O2 sensors and plug up your cats.
Old Mar 30, 2007 | 04:53 PM
cisurfer's Avatar
cisurfer
ok so i have emissions in NJ but i might be able to go to a private place and pass but if i cant i know they dont check under the hood....now if i do delete the egr ill geta check engine light and ill be able to pull codes but if i clear the codes will they come back....when i go thru the state inspection they use OBDII to read for codes so how can i prevent the codes from comin on once its deleted
Old Mar 30, 2007 | 07:35 PM
LilRoush's Avatar
LilRoush
If you clear the codes using a basic hand held OBD II reader, they will come back. However, if you use a tuner (Diablo, SCT etc...), you can close the EGR valve, delete the codes and it willnever show a thing on a check. I would suggest leaving the pipe from the passanger side manifold and the actaul EGR valve in place just in case at any point they pop the hood.
Old Mar 30, 2007 | 07:43 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Depends on how strict the emissions are in his state. Cali and AZ for example do an OBDII readiness check first before moving to the Dyno and sniff tests. The readiness test checks to see that all the electronics fuel delivery systems and emissionshave gone through a drive sequence. If one or more sensors shows it's not ready they will tell him to come back. If the system is disabled, it will never pass the readiness test.
jovez's Avatar
jovez
What do you think about capping the entryway into the intake? Would it work to just delete them in the runners and leave it at that? Or would it be best to cap it right after the EGR valve also.
Old Mar 31, 2007 | 02:26 AM
LilRoush's Avatar
LilRoush
If the computer thinks the EGR is there, it will think that when the valve is open the motor is getting more air than it really is. This will mean it's getting more fuel than air, and result in a rich condition. You'll see poor gas milage and fowled out sensors after awhile.
My understanding is that with the reprogram, you delete the system all together. So instead of just being there and disabled, it's gone completely. I could be wrong.
Old Mar 31, 2007 | 02:39 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
just move to TN....no emissions
Old Mar 31, 2007 | 11:00 AM
v6stang07's Avatar
v6stang07
or GA gotta love no emissions, b4 here i didnt even know what they were
vargas
Jun 17, 2017 12:17 PM
Vrooom
Feb 21, 2016 05:25 PM
TfcCDR
Sep 14, 2015 12:08 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Sep 1, 2015 08:16 PM
