"Check Engine Light"
My "Check Engine Light" came on Friday and i had a buddy hook up his OBII reader. The code came back as PO401. After looking around it seems like its an easy fix from what people say, but i have had this clicking noise comming from under my hood for a little while now too. My mechanic friend says it sound like an exhaust leak. I have been un able to find anything myself yet that seems to be leaking exhaust. I can't help but wonder if these two things could be related.
I have a 2001 3.8L vert with stock everything. I also just changed the spark plugs and wires last week at about 62,000 miles.Anyone know if these two things could be related?
the code is for the egr, its showing insuficent flow. maybe the connection from the header to the egr pipe broke some how and thats why its ticking and throwing a code. i would clean out the egr tube and valve and everything then disconnect the neg battery cable and reconnect then start it up again and take it for a drive. if it doesnt come back on then thats awesome if it does then you might need a new egr valve or dfpe..or whatever its called sensor..the silver box that connects to the rubber egr tubes.
ORIGINAL: amrcnidyot
http://www.moddedmustangs.com/forums/files/dpfe_215.gif
If you have no leaks, I would guess this is your problem as it controls the opening and closing of the EGRvalve. I would say you're stuck closed since it's giving an 'Insufficient' code.
Thanks for the info guys.. I'm gonna go ahead and replace the dpfe sensor tomarrow and take a look around the headers for an exhaust leak. Hopefully the dpfe will fix the check engine light, but i do need to get rid of that exhaust leak its SOOO annoying.
I have one concern, is this that DPFE sensor i need? http://www.napaautoparts.com/masterp...osition+Sensor
My Hanes book says i have two screws to take off but this one does not look like it has any screws to unscrew. If its right i'm ok with that but i dont want to throw 30$ away for something i don;t need to replace.
lincolnshibuya
Dec 8, 2015 04:37 PM
