Performance Shift Points
Old May 5, 2007 | 02:28 AM
eaglecatcher's Avatar
eaglecatcher
Default Performance Shift Points
I've got a 98 5spd, and I was wondering what are the best shift points for performance driving, like 0-60 or 1/4 miles, etc.
I was also wonderin if anyone knows of anywhere to find dyno graphs for my car (not mine, but you know what I mean). I doubt anyone woudl waste the money to dyno a stock car, unless they were about to tune it, but I'm just curious.
Old May 5, 2007 | 02:39 AM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: Performance Shift Points
Should be somewhere between 5500 and 6250ish...play around till you find her sweet spot
Old May 5, 2007 | 02:48 AM
raz54's Avatar
raz54
That sounds high to me since the split ports peak hp and tq are around 4200 (give or take a few hundred rpm) rpm. I know my peaks in that range and red line is 5500.
Old May 5, 2007 | 02:53 AM
ByPopularDemand
Mine shifts at 6 when im on it...Its not unheard of for some tunes to create a 6250 shift point though
Old May 5, 2007 | 02:54 AM
raz54's Avatar
raz54
ORIGINAL: ByPopularDemand
That's true but he didn't say he had a tune so I took it as stock.
Old May 5, 2007 | 03:00 AM
ByPopularDemand
THats why I said somewhere between stock redline 5500and 6250
Old May 5, 2007 | 03:30 AM
raz54's Avatar
raz54
Why would you want to go above red line? They peak in the mid 4000 rpm range which means they are no longer pulling after that and are actually slowing down. He is aking where are the best shift points and the best are when you are at peak tq.
Old May 5, 2007 | 04:22 PM
cominus's Avatar
cominus
ORIGINAL: raz54
I say 4500 each gear.
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
