Air/Fuel Mixture Gauge Help
I bought an auto meter air fuel mixture gauge this week for my mustang. I was going to install it today after I got the wiring diagrams off alldata. I am hooking up to driver side exaust manifolds first HO2s sensor. The high signal line which I need to hook it too goes to PCM which is behind the driver side kick panel. I removed the kick panel and took the wiring haresses off there bracket. The wire I was looking for was yellow with a light blue stripe. I couldn't find the wire at all though. Does anyone know which harness the wire is on? There were 4 of them I think behind the kick panel on the bracket. Maybe someone has done this before can help me out.
Also does anyone know where I can get a pod for the gauge, I have universal one but it doesn't fit right.
you are looking in the wrong place.... you want the passenger side kick panel, unbolt the wiring harness, its huge, 130? pin connector..... i think the one you want is # 60- or 70- something, its gray with a blue stripe
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
