Strange Issues
Old Jun 22, 2007 | 02:31 PM
Swirl's Avatar
Swirl
Default Strange Issues
I usually post over in the 5.0 section, but my wife has a 2000 v6.
Whenever she starts up the car it ticks and then it stops after the car is wamred up. What could be causing this?
Also, if you get on it, the battery light comes one. What could cause this?
Old Jun 22, 2007 | 02:44 PM
laserred02's Avatar
laserred02
Default RE: Strange Issues
The ticking is most likely the passenger side exhaust manifold, there is a known issue with them cracking over time because the A/C line drips condensation on them. The ticking stops because the manifold heats up and closes the hole. You can replace the manifold yourself it just takes some time to swap in a new one.
As for the battery light you should have the alternator tested, most auto parts stores will perform this check for free.
Old Jun 22, 2007 | 02:45 PM
Swirl's Avatar
Swirl
ORIGINAL: laserred02
Thanks!
She got it used from Carmax and still has the warrenty on it. We are going to take it to them to replace everything for us.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
