Brake Upgrade questions
ORIGINAL: jovez
Thats right, the rear calipers are the same as that off a v6, it just uses a different bracket to hold it better on the larger rotor. To "upgrade" your fronts, you need the rotors, calipers,brake lines, and pads. As for performance, you notice much better stopping power, but its not flying through the windsheild difference. Heres a pic i took from the ones i put in this past weekend(yes i know, dirty).
what rotors are those? just the stock ones? the brembos?
Ok, im sorry i just got back from class. They are the brembo rotors. buyfordracing has a kit. its the Mach 1 upgrade. its the one for $350. Theyre an ugly gray color when they come, i just painted them and put the hi temp decal.
edit: This is the kit i got:
http://www.buyfordracing.com/shop/pr...roducts_id=594
musnicki
Sep 23, 2015 07:11 AM
