EGR Error Code Question?
Old Dec 16, 2007 | 05:00 PM
birdoffire7's Avatar
birdoffire7
Default EGR Error Code Question?
My father has a 2002 vert with the 3.8L V6. His check engine light came on, we read it, and the code it gave was:
P401
Engine Gas Recirclation Flow - Insufficiant Detected
Has anyone seen this code or had to replace their EGR valve? I'm being told that these engines are known for the tendancy to have carbon build up on the ports which restricts the flow which in turn will throw this code. I'm also being told that this particular EGR valve's rubber parts tend to die after awhile due to heat. It's too cold to play with it tonight, but when we address it, should we try to clean first, just buy a new EGR valve, do both, or is it something else? Any input would be greatly appreciated. Thanks!
Old Dec 17, 2007 | 04:15 PM
blknismo180's Avatar
blknismo180
Default RE: EGR Error Code Question?
i had the code....mine was an easy fix it was just te dpfe sensor.....
i would check vaccum to the valve itself....and the hoses......
Old Dec 17, 2007 | 04:57 PM
Derf00's Avatar
Derf00
Gentleman's Relish
+1 on the DPFE valve/switch. Very common on 02-04 Ford models.
1TUFF302
Nov 5, 2015 04:02 PM
04stangman
Sep 17, 2015 01:45 PM
MusicCity615
Sep 12, 2015 07:05 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
