Squealing noise
Old Mar 25, 2005 | 02:24 AM
calo97sh's Avatar
calo97sh
Default Squealing noise
Any information from the following problem would be a great help, its a on and off squealing noise that also fluctuates in noise level, espically when the car is first started. The belt has been replaced, also the stationary and idler pulleys, the whole spring tensionar assembly, the water pump and its pulley. The ac unit and power steering unit are not making the noise but there is definetly a squeeling noise still emitting from the area of the belt, it almost sounds like a chirping sound because it fluctuates, definitely not constant. Its a 99v6 with 76k on it.
Thanks for any info.
Old Mar 25, 2005 | 03:17 AM
HRnB's Avatar
HRnB
Administrator
Default RE: Squealing noise
Try turning on your AC when the sound starts and see if the sound gets louder. I'm thinking your AC or PS pump are dragging.
Old Mar 25, 2005 | 07:52 PM
calo97sh's Avatar
calo97sh
Thanks for the info, tried and it looks like it would be the power steering, skipped right over the idea of the pump dragging, thanks for the info, suggest flushing the pump or just replacing?
Old Mar 25, 2005 | 09:09 PM
steve_mustang89's Avatar
steve_mustang89
ive got the same problem with my 89 LX, the belt squeals for abit when i warm it up but then it stops. i dont even have my A/C belt on because the A/C doesnt work. so would that be my power steering as well? if so, like calo said what do i do?
Old Mar 26, 2005 | 02:34 AM
HRnB's Avatar
HRnB
Administrator
A good way to know if it's a power steering pump is when you hear the squeel, turn the steering wheel all the way to the left or right and see if it gets louder. Because as you turn the wheel, pressure builds making the pump work harder and it will squeel louder and start to pulse.
Old Mar 26, 2005 | 02:53 AM
dc_mann8's Avatar
dc_mann8
when all the way to the left or right, like HRNB said, it should squeal like a neutered pig
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
ccdguy
Sep 19, 2015 05:20 PM
