GT rear end swap question?
Old Feb 8, 2008 | 10:47 AM
cominus's Avatar
cominus
Default GT rear end swap question?
Will a rear end out of lets say a 95 GT bolt right up to a new edge without any issues?
Old Feb 8, 2008 | 11:37 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: GT rear end swap question?
Its an narrower.
It'll work though, but best to find one out of a 99-04.
Old Feb 8, 2008 | 11:39 AM
Blainestang's Avatar
Blainestang
ORIGINAL: cominus
87-98 8.8 Housings are all essentially the same, and assuming 94-98 axles, everything should bolt up normally. The only significant problem would be that each side would be .75" narrower than it would be on a stock 99-04.
Old Feb 8, 2008 | 11:57 AM
H473R's Avatar
H473R
um, dont wanna hijack, but would a gt rear end from a 94-98 gt fit right on a 95 v6? and would it be worth it? and by fit, i mean not narrower, thx.
Old Feb 8, 2008 | 11:59 AM
NYstang's Avatar
NYstang
MF Staff Snitch
nope, for yours it would fit perfect
Old Feb 8, 2008 | 12:00 PM
Blainestang
ORIGINAL: H473R
Yes, it would fit "right"
Would it be worth it? Not unless you're making enough power to warrant it, OR if you can get one with gears and t-loc cheaper than installing them in your 7.5"... or some similar situation.
Old Feb 8, 2008 | 12:04 PM
H473R's Avatar
H473R
well, right now its a daily driver, and im getting a whine out of the rearend, idk if its my fuel pump and im just freakin out, or if its my rearend. either way this will be a track car with, if i can fit it, a big block with supercharger in it. if not then maybe either a sleeper sixx, or a 5.slow supercharged. so itll be useful later.
do the gt's have posi stock? or should i look for one with tlock and 3.73 gears at the same time?
Old Feb 8, 2008 | 12:18 PM
Blainestang
ORIGINAL: H473R
Well, if you're going for HUGE power, then you may end up with more than just a stock-ish 8.8, but it sounds like the 8.8 is the way to go for you if you're planning to replace stuff in the 7.5 anyway. MOST 8.8's have t-loc standard (confirm this on whichever one you're looking at), and if you can find one with the gears you want already installed, obviously that's good, too.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
