i ordered my 2 force pro's... when they get here im takin the cats off and doin an H pipe. then i got to worrying. whats gonna go on with my o2 sensor? will it try to lean it out and mess **** up?
long tubes? im not getting long tubes... but im sure if they wont hurt than shortys def wont. thanks. do most shops have tuners? how could i get eliminators and how di i put em on?
Without cats, your rear O2 sensors are going to think your car is running rich. In turn, it will pull out fuel, causing you to run lean. We all know what that leads to.
I thought that's what the front O2's do, the rear ones only measure how efficent your cats are working. Let me know if i'm wrong.
Well, all four work together to measure A/F and temp. The rear two are judging effective/defective cats as well based on the change between the upstream and downstream sensors.
