Transmission problem
Old Jun 8, 2008 | 02:17 PM
brent4's Avatar
brent4
Default Transmission problem
When im driving my 2002 5spd and have it under wot and shift from first to second my shifter will pop out of second. and then again when im slowing down and shift to secong gear. my car has about 120000 miles on it and the original clutch. is it time to replace it.
Old Jun 8, 2008 | 03:02 PM
jwog666's Avatar
jwog666
Default RE: Transmission problem
bent shift fork maybe, time to pull it out and go through it
Old Jun 8, 2008 | 03:19 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: jwog666
With his mileage, depending on how it's been driven, I would say it's probably not a bent fork, probably a bad synchro, seems to be fairly common with the new edges. I wouldn't rule out the bent fork though, it really depends if it's been mashed into the ground with only 120K. Regardless, time to break down the tranny and found out whats going on in there. GL
Old Jun 8, 2008 | 11:24 PM
tuflehundon's Avatar
tuflehundon
Had the same problem in my old eclipse. It was the clutch cable, it was way loose and would allow the clutch to disengage slightly. Had to hold it in gear. I replaced the cable, and the problem went away.
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
