quick nobb question
Old Sep 30, 2008 | 11:30 AM
l_shizzle_l's Avatar
l_shizzle_l
Drain plug is on the passanger side of the oil pan, right behind the tire. not on the back.
Any swaybar will help since the v6 did not come with one stock.
Old Sep 30, 2008 | 11:32 AM
moontang's Avatar
moontang
its not too bad i just pull it up on some small peices of 2x4's so the jack will fit under the bumper theres a trick for all you folks
Old Sep 30, 2008 | 01:43 PM
winner99's Avatar
winner99
Which is the cheapest good filter to use. I don want to use fram anymore.
Old Sep 30, 2008 | 02:27 PM
fordforlife0225's Avatar
fordforlife0225
idk yet how it is but i payed 13$ for my K&N. so you guys are saying a cobra rear swaybar will fit??
Old Sep 30, 2008 | 02:38 PM
bf4cm28's Avatar
bf4cm28
Motorcycle jacks work fine to raise one side of the car! I use mine to rotate tires etc.
Old Sep 30, 2008 | 02:40 PM
fordforlife0225
yea ill figure it out thanks, i think im going to just roll it up on the ramps and if it needs to drain more ill just roll it off the ramp and try and keep the oil bucket under it.
Old Sep 30, 2008 | 03:49 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
its 20% tint
and sorry for telling you the wrong spot...i use the New Posts tab, and i just reply anywhere on the board...i didnt realize this was a v6 thread lol my bad
Old Oct 1, 2008 | 11:14 AM
l_shizzle_l
Motorcraft. FL-400 i think. They are cheaper and better than fram.
Old Oct 2, 2008 | 09:02 AM
stanglover1250's Avatar
stanglover1250
Hope this helps man..
http://www.autohow.tv/node/11
Old Oct 2, 2008 | 11:46 AM
sransari's Avatar
sransari
psh, just go to jiffy lube for a simple oil change. just bring your own oil and oil filter and pay them the $25 in labor to change it. just ask them to let the car sit for 20 minutes before draining the oil out. oil change is so effing messy and hardly worth the $25 in savings.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
